Help with resetting the ECU.
Hello all,
I am having trouble resetting my ECU after some intake modifications. I am aware of the gas pedal method but am having trouble getting it down. I have done some research.
https://g35driver.com/forums/engine-...-easy-way.html
I am attempting the easy method but am a little lost on what to do between steps 2,3 and 4.
I understand i could do the neg battery terminal but i would like o get this down. Any helpful tips would be greatly appreciated.
Thank,
Thank,
keep trying it does work make sure nothing is on like ac or headlights and use a stopwatch and if you have a/t make sure it's warmed up seems to work for me on my altima ser my g seems to be easier.
Easier method instead of waiting 10-15 minutes after battery disconnect, press the brake pedal to the floor and hold it for a minute. Doing this 2-3 times discharges the capacitors and puts the ecu in learning mode, it also blanks stored codes so do a scan beforehand if the cel is on.
I've tried this before and it works, now that I have Osiris I just hit "reset learned fuel settings" and go for a rip.
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
benm722
Sep 20, 2015 01:29 PM
