Strange Idle Noise/Rattle
Old Aug 11, 2012 | 05:15 AM
crazynuts16's Avatar
So tonight I had this weird rattling noise from the engine when I parked my car. I noticed some rattling only at idle and when i pulled into the parking spot. It kept going unless I revved it even a little and then it would stop. My idle rpm was within normal range. I also noticed extra vibration in the steering wheel and on the floor board during the noise. It was a constant rattle, it would happen for 2-3 seconds, pause and then do it again. I tried to replicate again and i noticed it again once at a traffic light.
Now the only way to make it happen again is if I roll my windows up and down only using the auto switch. It doesn't work if i just hold the button and roll them, it only works if press the button and use the auto click to roll it.
Now I am thinking there might be an issue with the battery or the alternator. The battery is only a couple months old so I doubt its that. But these should be easy tests to perform, do you guys have any other ideas?
Oh and I did do an oil change, atf drain and fill, and differential couple weeks ago.
Thebaws11
Jul 2, 2021 11:36 AM
G35-R
Nov 7, 2015 01:21 PM
vamarris
Sep 26, 2015 12:56 PM
Jnm07
Sep 5, 2015 01:16 AM
pasjr1972
Sep 1, 2015 10:17 PM
