AC System Failure?
Old Aug 13, 2012 | 09:49 AM
Eskimo10's Avatar
AC System Failure?
2003 G35
48xxx miles
Recently my AC system started to go out, when I set it to 60, it only blows ambient air temp air. Thinking it needed a recharge, I went to WalMart and picked up an EZChill AC recharge can (18oz) and hooked it up following the proper instructions as per the can. Before proceeding to refill I checked the gauge and it reads 75psi!! So needless to say I didn't use the can.
My question is this: is there something I'm not doing right? Or could this be a compressor failure? Or some other part in the system?
Thanks in advance!
Old Aug 13, 2012 | 04:37 PM
TemjinX2's Avatar
are you sure you read the gauge correctly? i think stock is suppose to be around 30-35psi.
Old Aug 13, 2012 | 07:03 PM
Eskimo10's Avatar
Yes, the stock at temperatures between 75-85F should be around 35. But when I hooked up the gauge it shot up to 75psi. I'm not reading it wrong, I have a picture to show the needle at 75. I'm thinking that the compressor or something is bad, but I don't know why the pressure would be so high on it..
Old Aug 13, 2012 | 07:57 PM
TemjinX2's Avatar
did you check to see if the ac clutch is actually engaging when you turn on the ac?
have you checked the condensor to make sure there is no air flow blockages?
Old Aug 14, 2012 | 08:36 AM
Eskimo10's Avatar
No I didn't check that, I'm going to do that today since I had obligations last night.
How do I tell if the clutch is engaging?
Old Aug 14, 2012 | 02:08 PM
culi's Avatar
Did you connected it to high pressure line or low pressure line?
Old Aug 14, 2012 | 08:41 PM
TemjinX2's Avatar
you should see the hub connecting to the pulley when you turn on the ac and disconnect from the pulley when its off so the hub is free spinning from the pulley.
Old Aug 15, 2012 | 09:52 AM
Eskimo10's Avatar
Low pressure.
What do you mean by hub? I want to make sure we're looking at the same part.
Old Aug 17, 2012 | 06:47 PM
Eskimo10's Avatar
So today, after going to the gym the AC started blowing cold. But when I hit the interstate it started blowing warm. It seems like it only blows cold at low speeds, and sporadically at best.
Any thoughts??
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
doakley92
Sep 25, 2015 12:58 PM
