My AC stinks - how to fix?
Well, I picked up my G a couple of weeks ago. Needless to say, the PO didn't do his due diligence with the cabin filter
The car stinks, and although replacing the cabin filter helped, the car still smells like an old gym bag. I don't want to mask the smell with some Air Fresheners, rather I'd prefer to kill any mold/mildew. What's the best way to do this and what product do you recommend??
While I was in there I changed the plugs. Here's cylinder 1
How they were even firing is beyond me.
had the same problem. i created a thread about how mine turned out and theres also another option on this thread to take care of the smell.
https://g35driver.com/forums/g-spot/...wers-fast.html
Silencer_0 (08-27-2012)
I'm going to try doing the Lysol trick from the outside went near the battery, spray it in and let it sit. Sometimes its bad enough to make me gag lol
The guy at the dealer said if you always run your a/c in recirculation mode, it doesn't allow the hot air from the outside to dry out the vents.
So now I use fresh air mode more often to dry out the vents.
Here's the right way to do it. It's simpler than it seems. As a professional detailer, this is how I would do it. I would not trust the dealership to do a proper job.
Also, the car in the tutorial is a G35.
http://www.detailingbliss.com/forum/...pplication.htm
Yep this is true. Now i'm in the habit of turning off AC and having fresh air come in shortly before i get to where i'm going. Don't give mold any chance to take hold and grow.
