2003 g coupe won't start
Old Sep 12, 2012 | 10:54 AM
dr_scifi's Avatar
Click noise is always battery related. Did u check the power cable, all the fuses that connect to the batt?
Old Sep 12, 2012 | 11:44 AM
deasons22's Avatar
Yea I've checked the fuses on the power cable and yea I've sanded down the cables so they are cleaner then I've ever had them and the battery reads around 12.5 and 12.9 since I've been jumping it make. I've checked the cables and i'm just not seeing anything cut on the top or underneath.
Old Sep 12, 2012 | 04:18 PM
Killerzracing03's Avatar
Its not under the dash its under the battery cover my boy found it i made a thread about it ill check n post the link
Old Sep 12, 2012 | 04:36 PM
https://g35driver.com/forums/showthr...72#post6464672
Old Sep 12, 2012 | 07:19 PM
deasons22's Avatar
{Edit}
Yea Killerz, I've check all of the fuses, the ones on the cable, the little box next to the battery, and inside. I haven't done anything with the lights, so I really don't think this applies to me unless i'm missing something?
Old Sep 15, 2012 | 08:36 AM
tle.88's Avatar
I had a similar problem before too on my 03 350z turbo twin and don't know if this would help. Since your is tt also, I would use a one step colder spark plugs. Also make sure that the coil packs is plug up right, on my driver side valve cover I mixed the number 4 plug wiring with 6 and it will only start when it cold. Next check for any vacuum leaks like loose piping, couplers, etc. Finally you could check the fuel pump assembly make sure the fuel filter is not dirt, fuel pump is working, wiring on assembly is all good.
Old Sep 17, 2012 | 08:10 PM
deasons22's Avatar
Thanks, yea i'll check those things out.
Old Aug 4, 2013 | 02:38 PM
deasons22's Avatar
Issue Found
Finally got back to this and I think I found the issue. When I removed the starter I didn't notice a cable connected to the B terminal, so when I put the new starter in I didn't connect anything to it. I've removed the starter again and searched and can't find the cable that should go to the terminal. Anyone have this happen, I'm referring to the cable #5 in this diagram: http://img.photobucket.com/albums/v6...starterFSM.jpg
TWASkyliner
Feb 8, 2020 08:00 PM
R350k5
Oct 1, 2015 08:41 PM
andyg35c1
Aug 29, 2015 03:37 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
