Strange AFM Problem
Old Sep 11, 2012 | 08:08 AM
Tony Q's Avatar
Strange AFM Problem
Ok, I have just hooked up the vortech SC and the car idle and cruised perfectly. Then after a few drives, I decided to push it a little. When I accelerated, the motor cut off at 2200rpm (My first thought was Piping blew off after the AFM or the AFM is bad). So I brought the car home and shut it off and checked the piping. I gave it about 15mins then restarted it and I was able to rev normally. I then went out gradually accelerated and the car pulled well to 5000rpm. I tried to accelerate hard again and it cut off at 2200rpm.
I will be doing a boost leak tomorrow but I doubt that is the issue. Do you guys have any suggestions on what check?
Sorry, for the long post.
Old Sep 11, 2012 | 12:35 PM
06G35Coupe94's Avatar
Are you running some type of tune and if so was it tuned at a professional shop?
Old Sep 11, 2012 | 05:05 PM
Tony Q's Avatar
It has the splitsecond box, the previous owner had tuned. The funny thing is that I ran the whole setup for a week minus the SC and did not have any issues.
Thanks for the reply
Old Sep 11, 2012 | 06:14 PM
seymore4's Avatar
m56
Did it go into limp mode and not run until you turned it off and restarted?
I would go to a shop that has tuned boosted VQ's and invest in some proper engine management and a dyno tune.. before you have to invest in a new shortblock
G35xdriver04
Nov 7, 2015 08:31 PM
G35-R
Nov 7, 2015 01:21 PM
mattdg35
Sep 14, 2015 11:28 AM
pasjr1972
Sep 1, 2015 10:17 PM
