Hesitation at higher RPM
Old Sep 11, 2012 | 08:52 PM
Juelz905's Avatar
Hi all,
Car: 2004 G35 Coupe M6 (no mods bone stock except hid's)
It runs fine in lower RPM but as soon as it pass 4k it hesitates throughout acceleration..? it feels like fuel/air mixture ratio is off but im not throwing any cel's. the odb2 scanner shows my oxygen senors are operating normally.
I may also add i have the oil consumption problem, but this has just started happening and i always keep my oil topped up.
I've used the search button but can't find any answers.. Suggestions are appreciated.
HELP PLEASE,
Cheers
Old Sep 12, 2012 | 07:08 AM
TemjinX2's Avatar
Could be misfires..you check plugs and wires?
Old Sep 12, 2012 | 09:32 AM
herrschaft's Avatar
Does it only hesitate for a second, or for the entire RPM range above 4K?
Old Sep 12, 2012 | 12:35 PM
G35ergio's Avatar
mine used to hesitate at idle when you revved it. It was due to a misfire.
Old Sep 12, 2012 | 09:58 PM
Juelz905's Avatar
its intermittent throughout the power-band after 4k RPM.. its like a hiccup.. maybe its a misfire? I will inspect plugs and wires.
thanks all for the help thus far.
Old Sep 12, 2012 | 10:46 PM
TemjinX2's Avatar
then check coil packs if that doesnt fix it. But i bet its just spark plugs.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
aaron3719
Sep 29, 2015 10:12 AM
Hogbone
Sep 28, 2015 06:44 PM
Detailed Image
Sep 28, 2015 07:04 AM
vamarris
Sep 26, 2015 12:56 PM
