whats this problem suspension
Old Sep 20, 2012 | 07:34 PM
G35AlexG35's Avatar
Ok so when the steering wheel is straight one front wheel is straight and the other is slightly turned? its werid.. can it be alignment ?
Old Sep 20, 2012 | 07:36 PM
PAIXAO's Avatar
It's definitely alignment related
Old Sep 20, 2012 | 10:57 PM
gtkshadow's Avatar
aligment problem could be out of aligment and could be
sway bar link kits- they tie the wheel to the sway bar you can see them if you look under like by the brakes and they should connect to a bar
Old Sep 21, 2012 | 11:12 AM
onthe3rdday's Avatar
Endlinks shouldn't cause that. But take it to the suspension/alignment shop and they will pinpoint the problem for you.
Old Sep 21, 2012 | 11:39 AM
viciouzgamer's Avatar
I had a similar problem and it ended up being one of my control arms was broken
Old Sep 21, 2012 | 12:12 PM
gary c's Avatar
You need to get to an alignment shop before you lose a wheel or crash! Even if your alignment is off you shouldn't see what you describe, somethings broken....Gary
Old Sep 21, 2012 | 07:25 PM
serges's Avatar
Def. take to the alignment shop! These roads in Rochester r being fixed but still a work in progress. Weakens the suspension components quicker with all the potholes! I got mine memorized.
Old Sep 22, 2012 | 11:03 AM
G35AlexG35's Avatar
hahah you already know bro!
Old Sep 24, 2012 | 02:39 PM
VMRWheels's Avatar
Sounds like an alignment issue. Hopefully it's something that can be easily fixed.
snic09
Nov 8, 2017 01:46 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
TreeFiddy
Aug 10, 2015 06:50 PM
Fireman07603
Aug 9, 2015 06:00 PM
atk08
Jul 30, 2015 03:12 PM
