Check engine soon light on, code P0128
Old Oct 7, 2012 | 04:38 PM
baby G's Avatar
While driving last night the check engine light came on and it read a code P0128 which means that the coolant temperature is below the thermostat regulating temperature. Last night was the first cold night we've had so I feel like it has to do with that and that the thermostat is stuck open and not broken. If anyone has experienced this before what did you do to fix it. I don't want to replace the thermostat if it can't be unstuck by flushing the coolant.
Old Oct 7, 2012 | 10:52 PM
baby G's Avatar
I'm sure now that the thermostat is stuck open, does anyone know if flushing the coolant can fix that, or anything else that can
Old Oct 8, 2012 | 10:40 AM
gary c's Avatar
There's only one way to fix a broken thermostat, replace it! You could change fluids for ever and it won't fix what's broken/failed. Consider yourself lucky, if it would have failed closed you would have had overheating issues....Gary
Old Oct 8, 2012 | 02:15 PM
06G35Coupe94's Avatar
Buy an aftermarket one too. Since you have to replace it, just upgrade.
Old Oct 8, 2012 | 08:02 PM
gary c's Avatar
After market thermostats are not an upgrade, that's like drive belts the dealerships carry the best quality. His thermostat failed in the best possible way, keep it in the family....Gary
Old Oct 8, 2012 | 08:15 PM
PAIXAO's Avatar
^^ +1
If you want an upgraded thermostat go Nismo.
Old Oct 9, 2012 | 01:44 AM
jsmith29's Avatar
My nismo thermostat gave me +10 bhp. It also came with a sticker good for another 5.
Old Oct 9, 2012 | 08:08 AM
baby G's Avatar
I probably should have upgraded but I just got the regular one, it was 160 for the thermostat, coolant, and labor
Old Nov 13, 2014 | 07:21 PM
2legit2quit's Avatar
Reviving a really old thread. My check engine light came on yesterday and just pulled the same code. I guess mine failed opened cuz the check engine light came on while I was driving, just like the OP. I had just replace the OEM one with a Mishimoto about 6 weeks ago also. Nothing wrong with the OEM one as it was still working like a champ. My friend told me to change it also because I was flushing my coolant to get ready for winter. Lucky I still have the OEM one. Just need a warm place / garage to re-install it. Damn Chicago weather is too damn cold nowadays.
Old Nov 13, 2014 | 11:49 PM
partyman66's Avatar
Is the Mishimoto one that you put in rated for the same opening temperature as your OEM one or did you go with a lower temp rating?
Old Nov 14, 2014 | 09:39 AM
I went with a lower temp rating one. Bought it off fleabay for $60 and the seller did have a 99% rating. Just like this one...............
https://conceptzperformance.com/Cart...on.php?II=5323
Is there a difference? good? bad?
Old Nov 14, 2014 | 10:51 AM
partyman66's Avatar
That lower-than-spec thermostat is definitely why it's doing it then. The motor isn't reaching the specified coolant temperature in the required time, so it's tripping the P0128 CEL code. Our cars actually run pretty cool for the most part so there's not much of a need to use a lower temp thermostat really. When I drive in temps below 50 degrees, my car tends to hover at around 170 to 173 coolant temp as long as I am moving. That's extremely low for a 3.5 V6. My 2.7 4-cyl Tacoma runs cool as well, and that thing is usually in the 177 to 185 range regardless of conditions. I don't think I've ever owned a car that maintains such a low coolant temperature before aside from my G.
Muski_G
Dec 1, 2023 11:11 AM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
Jay 21
Aug 5, 2015 04:53 PM
ClwMike
Jul 23, 2015 12:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
