Slip light and VDC light stay on
Old Jan 20, 2005 | 11:49 AM
MADDD_G's Avatar
Hey fellow G members,
Seems like a very odd problem. I just got my car alligned. After about 15-20 minutes of driving my slip light and VDC off light BOTH come on at the same time and stay on until i restart my engine. DOes anybody know what may be causing this problem? I appreciate your help.
Old Jan 20, 2005 | 12:35 PM
DiamondGCoupe's Avatar
Does it do it everytime you drive or just that one time after you had it aligned?
Old Jan 20, 2005 | 12:41 PM
sen_jen's Avatar
Meatshake Enterprise
seems like either an electrical problem, or the place you aligned your car at messed up.
Old Jan 20, 2005 | 12:51 PM
MADDD_G's Avatar
Yes, it does seem like an electrical problem or maybe a problem the ECU is seeing. As a matter of fact, there is a slight error to the allignment of the car. The car drives straight ONLY if the steering wheel is placed at 11:00 position, which might confuse the ECU to think the car is slipping when its just an allignment issue. Thats the price you pay for trying to save 30 on allinment. : (
This would be my only theory. I''m gonna try taking it to Nissan today to have the car re-alligned. Thanks guys
Old Jan 20, 2005 | 12:53 PM
MADDD_G's Avatar
Yes, the problem happens everytime after around 10 minutes of driving.
Old Jan 20, 2005 | 03:26 PM
Draco24433's Avatar
Amigo,
Don't worry. I had the same problem except I also had the ABS light light up also. It is a brake sensor that's bad. I just had mine replaced and I think there is also a TSB on it. I hope this helps.
DJ
Old Jan 20, 2005 | 03:31 PM
Msedanman's Avatar
O.F. Administrator
Sounds to me like the alignment techs may have knocked of an ABS sensor, or otherwise upset something at one or more of the wheels.
I doubt that the steering being off a few degrees would cause the lights to come on.
Other things that might turn those warning lights on are: low b/fluid level, a faulty brake pedal switch (see TSB's), thin brake pads, wrong sized wheels/tires...........
none of which seem to apply.
G/L
Old Jan 20, 2005 | 03:32 PM
TINMAN's Avatar
Madd...does the ABS light came on also?
Old Jan 24, 2005 | 04:37 PM
hata7443's Avatar
I drive the 04 G35x. Yesterday when I started the car, the VDC light, the Slip light, the ABS light, the AWD light and the check engine light all came on. Also the speedometer and the odometer stopped working too. The dashboard lighted up like a christmas tree. The car drives fine though. Although I can't tell how fast I was going.
Last week I scheduled an oil change at the dealership for tomorrow, so I guess I'll know what's wrong tomorrow.
Old Jan 24, 2005 | 06:33 PM
Msedanman's Avatar
O.F. Administrator
LOL, sounds like the ECU/BCM had a meltdown......sometimes these things happen and just as quickly clear themselves.
Old Jan 25, 2005 | 12:21 AM
RedefinedG35's Avatar
mine went off Brake/Slip/VDC OFF lights came on and i put more brake fluid in and it stopped not saying this might be the problem just saying how i solved mine
Old Jan 25, 2005 | 01:04 PM
hata7443's Avatar
The malfunction lights stayed on this morning as I drove the car to the dealership. The service advisor said it was due to the cold weather (-30C in Toronto yesderday). Didn't make a whole lot of sense to me, don't people drive Infinitis in cold weather? Oh well, I'll know what's wrong for sure when I pick up the car.
Old Jan 25, 2005 | 03:35 PM
hata7443's Avatar
The verdict is in. A cable that connects the speedometer broke.
The car is only 3 months old.... and it is going to take 2 to 3 days to order the parts and fix the problem.
I hope this is not a sign of things to come. I had an Infiniti before and it was quite reliable.
Old Jan 26, 2005 | 03:30 PM
JDMSkyline's Avatar
last time I had the lights come on i brought it in to infiniti and turns out that my brake pads were worn out (even though it wasn't screeching)...03.5 5at coupe btw
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
