Driver side keyhole Cover..
Old Oct 17, 2012 | 06:49 PM
Geewhiz420's Avatar
Well basically my keyhole cover, (a Normal one with the hole for the key) and it seems to easy to pull pull off. I was wondering if there is a quick fix for this? Do I need to snap it into place? Also when the cover is off, the Lock itself seems moveable, Can wiggle.
I checked threads on this, I couldn't find much.
Thanks
Old Oct 17, 2012 | 08:39 PM
dukehotty's Avatar
I purchased one of the key hole covers without the hole since I have the Intelligent key. My old one popped right off so I used a couple drops of super glue to keep it on a little more tightly. It will still come off but it will take a little more effort.
Old Oct 18, 2012 | 08:02 PM
blAk mAx's Avatar
key hole delete or echelon
Old Oct 19, 2012 | 03:54 PM
jonesmeister11's Avatar
OP, if you havent glued yours back on please post a pic of the cover. mine was on the ground one morning and I'm wondering if someone tried breaking in my car, based on the back of the cover it looks like it was pried off. My neighbors car was broken into the next day.
Old Oct 19, 2012 | 07:02 PM
Geewhiz420's Avatar
Alright I will, Mine doesn't look pried off, Possibly didn't snap in or missing a screw? At the moment I have it staying on with Double sided tape, Hoping to find a fix soon for it, Not having to rely On glue.
Old Oct 19, 2012 | 10:08 PM
dj714's Avatar
I think it should span back in to place with the interior plastic door handle bracket.
Old Oct 20, 2012 | 02:10 PM
Geewhiz420's Avatar
Update: I just checked, and unplugged the door, where the screw holds the lock securly in place. I have tried to screw it back in but I am having a hard time getting it to start "screwing" in, and gettting it tight. Any ideas? The screw is still there, just hanging on by the brackets to not let it go, but it is not screwed in or tight.
Old Oct 20, 2012 | 02:33 PM
dj714's Avatar
Make sure that the plastic inside clips over the door lock hole. If not it won't aline correctly
Old Oct 20, 2012 | 02:35 PM
dj714's Avatar
[IMG][/IMG]
Old Oct 20, 2012 | 04:50 PM
Geewhiz420's Avatar
is that the screw that pops in? Also I can't pull the lock all the way out like that, or don't want too, Am afraid I will mess it up.
Old Oct 20, 2012 | 04:57 PM
dj714's Avatar
Yup that's the screw.
Old Oct 20, 2012 | 05:11 PM
Geewhiz420's Avatar
And did you have to pull the whole lock part out? ( Mine seems to just be loose, but Im not sure if i should try to pull it all the way out, Don't want to break my door lock, and have it not be able to lock.
Old Oct 22, 2012 | 11:39 AM
^^^ oh snap I misread your thread. heres what I was under the impression you were talking about.]
Sorry for the huge pics, but I'm in class and don't have time to resize them.
Old Oct 22, 2012 | 11:54 AM
Junkanoo's Avatar
Dat Hand...
Old Oct 22, 2012 | 01:33 PM
dukehotty's Avatar
That is the part I thought he was talking about too. As per my previous thread, DO NOT use superglue if you aren't talking about the part pictured above!
Those hands do need some Aveeno.
