Desiel fuel in my g35 :((((
Old Oct 28, 2012 | 05:27 PM
Robel Yohannes's Avatar
Originally Posted by KrazySouthG35
You could siphon it out or drop the tank and dump it out...I'd siphon it then add some regular gas to "rinse" it out then siphon that out then fill it up
how can I drop the tank ?
Old Oct 28, 2012 | 05:29 PM
Lone Wolf's Avatar
Originally Posted by Lone Wolf
Did you choke your sister yet?
Old Oct 28, 2012 | 05:30 PM
she left the house. I honestly came in raging wanting to rip her head off so she just dipped.
Old Oct 28, 2012 | 05:32 PM
how long would syphoning the tank take??? and is it easy to do?
Old Oct 28, 2012 | 05:34 PM
KrazySouthG35's Avatar
I don't know that maybe someone else will chime in? Siphoning should accomplish the same thing though. It's gonna run rough while it runs out what's in the lines but as long as it stays running it should clear up after that. Keep it revved up while its clearing out
Old Oct 28, 2012 | 05:35 PM
You can buy a siphon at lowes and places like that time depends on how full your tank is...but you don't have many choices haha
Old Oct 28, 2012 | 06:08 PM
JOKER's Avatar
CLUB MODERATOR
Originally Posted by dominate
Sorry to be the bearer of bad news, but one of my friend told me of a story of how one of their friends put diesel in a scion. The engine was shot and had to be replaced
that's a load of BS
diesel is more oily than gas, so it will damage absolutely nothing but your fuel filters.
What you need to do is drain your fuel tank
replace your fuel filters
blow out your fuel lines
fill everything up with gas and start her up.
it will run rough for a little bit until all the diesel is out of the system and should be back to normal in no time after.
Maybe do a seafoam treatment to the fuel and engine.
Old Oct 28, 2012 | 06:13 PM
ilovez33's Avatar
Originally Posted by JOKER
that's a load of BS
What he said. Seafoam will clean a lot of the residual diesel left. Plus seafoam is awesome.....Pretty sure it can cure cancer
Old Oct 28, 2012 | 06:15 PM
thescreensavers's Avatar
Mr.202?
seafoam wont do jack **** Youd just be adding more oil into your fuel.
Old Oct 28, 2012 | 06:17 PM
ilovez33's Avatar
Stahp it danny! You know seafoam works wonders in everything!
Old Oct 28, 2012 | 06:27 PM
Do g35s have drain plugs??? Maybe I can do that and get all the desiel out.
Old Oct 28, 2012 | 06:35 PM
partyman66's Avatar
How did she manage to do that? Usually the diesel pumps have a different sized nozzle so idiots don't accidentally fill up a gasoline car with diesel. My friend accidentally tried to do it to my car one time back in college during a road trip, and that was the only thing that prevented it from happening.
On the bright side, at least your sister attempted to put some fuel in the car... LOL.
Old Oct 28, 2012 | 07:13 PM
jutn35's Avatar
G35 Coupe
take out the back seats, and open up the hole to the gas tank and siphon on the gas tank, but how do you manage to put diesel in , isnt there a coil around the diesel nozel that prevents you from putting it in the gas hole for regular cars ? But the injectors are probably ****ed , i dont know too much about fuel systems
Old Oct 28, 2012 | 08:01 PM
terrorx7's Avatar
Also check to make sure your fuel filler nozzle is not damage. Usually the Diesel filler is larger in diameter than a non-Diesel one so your sister must have jammed that nozzle in there. I know because my sister-in-law did the exact same thing to her Civic.
Old Oct 28, 2012 | 08:15 PM
  #30
ilovez33's Avatar
Lol....I don't understand how one could accidentally fill diesel in a gasoline car....The hose is usually separate from the gasoline ones. Only thing I can say is maybe she has a diesel car and is second nature.
