My Various Coupe Newbie & Mod Questions - Please Help
Old Feb 11, 2013 | 01:16 PM
  #121
saywat?'s Avatar
for the record the lip flying off has more to do with install error
Old Feb 11, 2013 | 03:23 PM
  #122
LxV Socal's Avatar
Yup the screws provided were too short as they didn't pierce through enough.You get what you pay for
Old Feb 11, 2013 | 03:26 PM
  #123
saywat?'s Avatar
^so u didnt even use double stick tape to secure the entire middle section of the lip?
also most bodykit sellers do not provide any hardware at all. and for the screws ur supposed to use a metal clip thing that tightens with the screw. idk wat its called but most people dont use it so the screw is never fully secured
Old Feb 11, 2013 | 09:29 PM
  #124
LxV Socal's Avatar
The double sided tape provided was pretty thick.about .1000 inch thick which was probably what didn't let the screws pierce through enough
Old Feb 11, 2013 | 10:42 PM
  #125
saywat?'s Avatar
I see. But normally tape wouldn't be applied to the area where the screw is
Old Feb 12, 2013 | 08:38 AM
  #126
zzoeller's Avatar
I vote color marched to your car
Old Feb 12, 2013 | 04:54 PM
  #127
tszyuenc's Avatar
paint paint paint!!!
Old Feb 12, 2013 | 09:23 PM
  #128
LxV Socal's Avatar
Is it time for new bushings?
Just about a week or 2 ago my suspension started making popping and squeeking sounds when I'm doing a wide turn at a really slow speed or when slowly go over dips/bumps,once you pass 5 mph or so their are no more strange sounds.Handling still feels nice and smooth the only thing is that it makes sounds and it gets a bit worse everyday.do I need new compression rod bushings or LCA bushings?
Old Feb 12, 2013 | 09:43 PM
  #129
jasonseoguam's Avatar
yes
Old Feb 12, 2013 | 11:45 PM
  #130
LxV Socal's Avatar
Originally Posted by jasonseoguam
yes
Rod bushings,lca bushings or both?
Old Feb 13, 2013 | 05:46 PM
  #131
Blue Dream's Avatar
I drove ttrank's car solo
You won't know until you inspect them. Could also be your front endlinks, they're notorious for failing. If it is the endlinks replacements are pretty cheap.
Old Feb 19, 2013 | 01:58 PM
  #132
LxV Socal's Avatar
Checked it out today and both of of LCA bushings were blown.My control arm slides and comes into contact with metal.Should I get OEM bushings or go with aftermarket?
Old Feb 19, 2013 | 02:27 PM
  #133
Peoria35sedan's Avatar
^^ Use aftermarket, I have about 40,000 miles on energy suspension bushings and they've been great. Do the compression rods while you have it apart. You can buy a front end kit for $100 from most of the vendors, I got mine at CZP.
Old Feb 19, 2013 | 04:46 PM
  #134
LxV Socal's Avatar
This would be it?
R350k5
Oct 1, 2015 08:41 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
BlackGee35
Jul 21, 2015 07:24 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
