Changing HID Bulbs - 03 G35 Coupe
Old Nov 20, 2012 | 01:25 PM
G35-R's Avatar
2003 G35 Coupe 6MT
Does anyone have any quick tips on how to change these bulbs or recommend a place with reasonable prices?
Old Nov 20, 2012 | 01:32 PM
Plur's Avatar
Jack up your ride, remove the wheel and go thru the front panel. It's quick.
Old Nov 20, 2012 | 01:33 PM
KrazySouthG35's Avatar
Some people pull the wheels off and access them through the wheel well some people pull the bumper off and pull out the whole assemblies. I pulled the bumper when I did mine. Pop off the black cover on the back of the assembly, turn and pull off the harness, pop the clips holding the bulb, then replace the bulb and reverse the process. Pretty straight forward
Old Nov 20, 2012 | 04:43 PM
XLR8_'s Avatar
Jacking the car up and removing the wheels imo is way faster.
Old Nov 20, 2012 | 06:04 PM
saywat?'s Avatar
turn wheel all the way inwards, jack up side and remove the top middle area of fender well. ull have all the space u need . no need remove the wheel
Old Nov 21, 2012 | 02:36 AM
TemjinX2's Avatar
I found just pulling down the bumper and removing the head lights was easier..lol.
But yeah going through the inner fender is the more conventional way, but you still need the hands of a hobbit to install it.
Old Nov 21, 2012 | 10:29 AM
DKano's Avatar
I've actually done it both ways, turn the wheels all the way in and then remove the fender liner (for just changing bulbs this is easier), and also move the bumper down. Lately I've been pulling the bumper down and removing the whole assembly just because I've also had to do some other work on the headlights.
Old Nov 21, 2012 | 12:22 PM
ishiftinheels's Avatar
Teh Redhead Moderator
THIS x 100000
Don't take the wheel off, that's wasted effort.
Turn your steering wheel all the way so that the wheel is facing inward, one side at a time obviously, and you can access the bolts holding the bumper into place. Once you take the front bumper off there are only 3 bolts holding each headlight in place. I've done this many times (Swapped headlights 3x and removed/replaced front bumper countless times). The bumper bolt that's the farthest inside is the hardest to get to but can still be done without removing the wheel.
Old Nov 21, 2012 | 03:41 PM
driftsucky's Avatar
Yeah. No need to take off the bumper NOR the wheel. But, it's only "relatively" quick compared to the other way if you go through the fender liner. If you've got hobbit hands, you can just pop the hood. I saw a guy do it once. True story. But, my hands, like the rest of me, are huge.
Old Nov 22, 2012 | 12:49 PM
serges's Avatar
Super easy thru the fenders I didnt even need to do anything on the pass side. Just push the liner down and poke ur hand in there!
Jusseth
Sep 13, 2020 12:25 PM
R350k5
Oct 1, 2015 08:41 PM
teamghost
Jul 28, 2015 04:52 PM
ClwMike
Jul 23, 2015 12:55 PM
attarday
Jul 15, 2015 04:03 PM
