Front Lower Steering Knuckle
Old Dec 2, 2012 | 05:48 PM
G35-R's Avatar
2003 G35 Coupe 6MT
I've notice my front steering knuckle boot is cracked and is leaking grease. Is there aftermarket replacments versus the factor replacement of the entire arm for about $300 each side?
Thanks for everyone's help.
Old Mar 4, 2015 | 08:14 PM
kchar92's Avatar
Bump
I need help with this also
Old Mar 4, 2015 | 08:22 PM
ScraggleRock's Avatar
As long as you aren't an X, yes. CZP has them for $45/ea
Old Mar 4, 2015 | 09:07 PM
kchar92's Avatar
Dealer said I need to replace both front steering knuckles, but can I just replace the ball joint instead of the whole arm?
Old Mar 4, 2015 | 09:26 PM
Wait, arm or knuckle ball joint?
If you're talking about the compression rod (aka radius arm; aka front rear control arm), then no the ball joint is irreplaceable and you must get a whole new arm. If this is the case, look on rockauto. They've got plenty of affordable options.
If you're talking about the steering knuckle balljoint, then yes its replaceable, but Infiniti will not sell you just the ball joint. They'll only sell you the whole assembly ($$$)
A few aftermarket companies sell the steering knuckle ball joint by itself. CZP is the cheapest and I've had them on my car for 25k miles and they're all good. Duralast (autozone) also makes them, mevotech (these are cool cuz they have a zerk fitting), and a few others.
Old Mar 4, 2015 | 09:37 PM
kchar92's Avatar
Sorry. I think it's the steering knuckle ball joint. On the invoice I got, it says both front lower ball joints leaking
DarkLyter
Jul 28, 2015 04:57 PM
teamghost
Jul 28, 2015 04:52 PM
itschuckster
Jul 25, 2015 08:07 AM
jimNC
Jul 25, 2015 05:47 AM
Karnicle
Jul 23, 2015 05:08 AM
