Mishimoto Oil Cooler Kit
Old May 4, 2013 | 10:39 PM
Dynasty21's Avatar
Have the Mishimoto Universal oil cooler kit with thermostat for 3 yrs and counting and no issues. I also run the bigger oil filter meant for FX/M. Its my DD, ProCharged for 35k miles and counting.
Old May 6, 2013 | 12:09 PM
mishimoto's Avatar
Originally Posted by lostangels01
The Stillen requires their Oil Cooler Kit to use Fram Oil Filter. Does your require a certain oil filter or its universal?
The Mishimoto kit is designed to use the OEM filter. That being said most filters with M20 X 1.5 threads will work as long as the diameter of the filter is no greater than 67mm (Filter sealing surface of sandwich plate). Also if you plan to use a different filter consider the length and any obstructions that would prevent it from fitting.
Awesome! Great to hear thanks.
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
NohoG35revup
Aug 22, 2015 12:13 PM
newg37
Jul 26, 2015 09:32 AM
