"Auto" Headlights Not Shutting Off?
Old Feb 4, 2013 | 12:28 PM
Kyle Barbaro's Avatar
Hey guys, at night I always put my headlights on "Auto" however after parking and turning the car off my lights never go off. Ive locked the doors, waited around for a bit, but the lights still stay on. Anything you can suggest? BTW ive searched the forum and couldnt find anything so please dont bash me or say its been covered before.. 05 coupe btw.
Old Feb 4, 2013 | 05:05 PM
fchdx's Avatar
Usually takes around a minute for me for it to shut off
Old Feb 4, 2013 | 06:37 PM
cvipgo's Avatar
you can program time for auto shut off, instruction in the owner's manual
Old Feb 5, 2013 | 08:05 AM
05CoupeMT's Avatar
G35 Coupe 6MT
Care to share the instruction info?? no owner's manual here.
Old Feb 5, 2013 | 08:56 AM
cvipgo's Avatar
you can down load from here: http://x.infinitihelp.com/forum/loca...s.php?catid=22
Old Feb 5, 2013 | 10:50 AM
jstudrawa's Avatar
2007 owner's manual doesn't mention anything to do with changing the timing...
The autolight system can turn on the
headlights automatically when it is dark,
and turn off the headlights when it is
light, and keep the headlights on for 45
seconds after you turn the ignition switch
to the OFF position and open any door
then close all the doors.
If the ignition switch is turned off and one
of the doors is opened and this condition
is continued, the headlights remain on for
5 minutes.
That's all we get.
Old Feb 5, 2013 | 11:05 AM
cvipgo's Avatar
According to ECM: Sensitivity of auto light can be selected and set from four modes.
DATA MONITOR
Operation Procedure
1. Touch “HEADLAMP” on “SELECT TEST ITEM” screen.
2. Touch “DATA MONITOR” on “SELECT DIAG MODE” screen.
3. Touch either “ALL SIGNALS” or “SELECTION FROM MENU”.
4. Touch “START”.
5. When “SELECTION FROM MENU” is selected, touch items to be monitored. When “ALL SIGNALS” is
selected, all the signals will be monitored.
6. Touch “RECORD” while monitoring, then the status of the monitored item can be recorded. To stop
recording, touch “STOP”.
Display Item List
Work item Description
CUSTOM A/LIGHT SETTING
Auto light sensitivity can be changed in this mode. Sensitivity can be adjusted in four modes.
 MODE 1 (Normal)/ MODE 2 (sensitive)/MODE 3 (Desensitized)/MODE4 (Insensitive)
ILL DELAY SET
Auto light delay off timer period can be changed in this mode. Selects auto light delay off timer period among eight modes.
 MODE 1 (45 sec.)/MODE 2 (OFF)/MODE 3 (30 sec.)/MODE 4 (60 sec.)/MODE 5 (90 sec.)/MODE 6 (120 sec.)/MODE 7 (150 sec.)/MODE 8 (180 sec.)
Old Feb 5, 2013 | 11:22 AM
jstudrawa's Avatar
Is this for those with Nav?
Old Feb 5, 2013 | 11:40 AM
cvipgo's Avatar
Applies to both w Nav & without
Old Feb 5, 2013 | 12:46 PM
jstudrawa's Avatar
I have to admit I am completely confused. Can you clarify? Is this while tuning?
Old Feb 5, 2013 | 08:30 PM
cvipgo's Avatar
Automatic headlights off delay You can keep the headlights on for up to 180 seconds after you push the ignition switch to OFF and open any door then close all the doors.
You can adjust the period of the automatic headlights off delay from 0 seconds (OFF) to 180 seconds.
For automatic headlights off delay setting, see ªAutomatic headlights off delayº in the ª4. Monitor, climate, audio, phone and voice recognition systemsº section:
Autolight system:
The autolight system allows the headlights to be set so they turn on and off automatically.
To set the autolight system:
1. Make sure the headlight switch is in the AUTO position q1 .
2. Push the ignition switch to the ON position.
3. The autolight system automatically turns the headlights on and off.
To turn the autolight system off, turn the
switch to the OFF, , or position.
light.
If the ignition switch is pushed to the OFF
position and one of the doors is opened
and this condition is continued, the headlights
remain on for 5 minutes.
Old Feb 5, 2013 | 09:02 PM
herrschaft's Avatar
Or just simply turn the lights "OFF", does the trick every time.
Old Feb 5, 2013 | 11:22 PM
cvipgo's Avatar
Or just get a horse cart😜
Old Feb 7, 2013 | 07:24 PM
Scotty87's Avatar
this just happened to me as well. I came home with my lights on auto, parked the car went inside and about 3 hours later I come back out to leave and sure enough...my car is dead. so next time I drove somewhere I left it on auto and monitored it..they didn't turn off. then I noticed even with the lights in the "on" position when I opened my door I didn't hear that annoying beep telling you that your lights are still on..so I'm wondering if for some reason the car thinks the keys are still in the ignition? btw I have an 04' 6mt coupe
Old Feb 7, 2013 | 07:28 PM
cvipgo's Avatar
You need to check your battery and or the light sensor or the relay that controls the headlight switching on and off while the it's on Auto
