ARC V1 Oil Catch Can Install and questions.....
Old Feb 20, 2013 | 02:31 PM
serges's Avatar
Not sure where to ask my questions but got a arc occ v1 and has a drilled hole where I assume is a breather valve... first of all is this compati my my revup?
Should I tig weld a small plate to cover the hole?? Forgive me learning my engine so u can call me a newb... I just need advice...???
Old Feb 20, 2013 | 11:03 PM
serges's Avatar
Update**** sent to the welding shop to cover hole in the top!!! My initial understanding of the tank is that it hooks up to the plenum from the side... the top opening is the breather opening... I seen people route a tube to the ground from the tank so oil smell does not go in cabin... any input is muchly appreciated!!! Thanx!!
Old Feb 21, 2013 | 10:49 AM
gary c's Avatar
Looks like you got the wrong catch can for our VQ motors, we don't have/use breathers. One line comes from the plenum the other goes to the top of your valve cover left side facing your motor.
Gary
Old Feb 21, 2013 | 11:05 AM
serges's Avatar
Thats what I was thinking but it is for the 350z vq35de just wondering if it can be modified to include a return line??
If not will sell on my350z forums for cheap atleast the gaudy hole will be covered and a fresh decal and polish should return my funds!!
Old Feb 21, 2013 | 11:45 PM
VQ Johnny's Avatar
I though you could hook the larger line on the other side of the plenum running to the g/z tube into the can as well and block the hole in the g/z tube? Isn't that how the g35 arc can runs?
Old Feb 22, 2013 | 12:11 AM
serges's Avatar
I have no idea...^^^^ I need some input I can possibly modify it if thats possible?? Weld a bung or something?
Old Feb 22, 2013 | 01:18 AM
gary c's Avatar
Hello Nightmare....=o(
What you have is so far off what you need the only smart solution is to buy the correct catch can and sell what you have. Google "Catch Cans" you can see both the inlet/outlet are on top and that's removeable so it can be emptied. I'm running a C6 Vette catch can and it works great....Gary
Old Feb 22, 2013 | 08:56 AM
serges's Avatar
Its got a drain on it??? I mean this is for a 350z so whats the difference??
Old Feb 22, 2013 | 11:07 AM
gary c's Avatar
Glad this is your nightmare, not mine!
I just did a 20 minute search, no one makes a vented catch can for our VQ motors including ARC! Where did you buy this from, is it possible they sent you the wrong can?You need find out from where you purchased this can from why they sent you the wrong one....Gary
Old Feb 22, 2013 | 11:48 AM
serges's Avatar
Go on my350z theres plenty of people using these gary??? I bought this right here on driver... im not sure if its vented but I know aam used to mod these to fit fi set ups.... its a arc v1 oil catch can... its official had a nice decal on it but making another one and then polishing it all up either for use or fs...
Old Feb 22, 2013 | 11:53 AM
VQ Johnny's Avatar
This one right?
You probably saw this but just in case
http://my350z.com/forum/engine-and-d...plug-size.html
Old Feb 22, 2013 | 12:06 PM
serges's Avatar
Yes!^^^^^
Old Feb 22, 2013 | 12:47 PM
VQ Johnny's Avatar
From what I remember it was designed to be FI compatible, that big port is the is where you would run extra lines.
Old Feb 22, 2013 | 01:08 PM
serges's Avatar
Hmm I seen na 350z use it tho I guess I dont get it? (
Old Feb 22, 2013 | 01:16 PM
SAMzG35's Avatar
G35
What's the point of a catch can serges?
