G35 Newbie Questions
Old Mar 4, 2013 | 03:09 PM
partyman66's Avatar
Originally Posted by maclovio
when was the last time you changed trans oil?
That's exactly what I was going to ask. There's a chance that whoever last changed it may have used subpar fluids in the transmission resulting in unusually notchy shifting. You might want to also make sure that your tranny fluid is filled to spec. Low fluid can result in noticeably notchier shifting.
Old Mar 4, 2013 | 03:15 PM
Marfyyyy's Avatar
It's more the roughness when shifting gears that disturb me I've driven a few cars where it's shifters are smooth and easy to shift but on my g35 it's so rough and due to that it lacks my timing whenever I wanna go fast
Old Mar 4, 2013 | 03:52 PM
Kicknshift's Avatar
That's funny. I test drove a couple G's the clutches are 5x lighter than my mustangs clutch. I really appreciated the lightness of it. Maybe because my left leg is like a tank now.
Old Mar 4, 2013 | 04:38 PM
MDH713's Avatar
^^^ Go with what they said and find yourself a nice pair of 06 projectors, you won't regret it. I just picked up a nice clean pair for 375 last week! There is always some popping up in the marketplace.
Old Mar 4, 2013 | 05:17 PM
SAMzG35's Avatar
G35
Now that's a steal.
Old Mar 4, 2013 | 05:21 PM
SAMzG35's Avatar
G35
I never found my clutch pedal stiff not with my stock clutch nor JWT. My only complain was the engagement point. Too narrow, the RJM pedal made taking off and 1-2 shifting feel proper. It definitely wasnt.
Old Mar 4, 2013 | 05:28 PM
partyman66's Avatar
Were these other cars that you drove front wheel drive? With RWD cars, your shift lever goes directly into the transmission, so they tend to have a more mechanical feel to them. A front wheel drive car has the shift lever connected to the transmission by a long shift linkage that runs all the way from the shifter to the engine bay. The shift linkage can absorb a pretty good amount of the mechanical vibes that you normally feel in a RWD transmission.
Old Mar 4, 2013 | 05:45 PM
MDH713's Avatar
I know right. Im half tempted to even put them on and just resell them. I'll try them out for a little bit before i let them back go. Should make a little profit off of them.
Old Mar 4, 2013 | 05:49 PM
Marfyyyy's Avatar
Well I never knew that point but I drove an s14 and it was smooth also
Old Mar 4, 2013 | 05:53 PM
SAMzG35's Avatar
G35
I wouldn't. With the selling price doubling up they'll be much harder to find for a decent price. This has to be the best upgrade you do to an 03-05 coupe.
Old Mar 4, 2013 | 10:30 PM
herrschaft's Avatar
Hit the gym
Old Mar 4, 2013 | 11:33 PM
tszyuenc's Avatar
Originally Posted by SAMzG35
I bought this over a year ago. Well worth every penny.
http://www.rjmperformance.com/350z--...edal-kits.html
thats right this should be the first mod for every 6MT driver!!!
Old Mar 4, 2013 | 11:37 PM
tszyuenc's Avatar
+1 on the 06+ oem projectors
my friends got the ebay cheap headlight and they look "cheap"
Old Mar 4, 2013 | 11:58 PM
HenryLee's Avatar
Change the clutch fluid. It really helps.
Old Mar 5, 2013 | 05:25 AM
  #30
SAMzG35's Avatar
G35
I haven't done mine in a while. Definitely on my todo list.
