G35 Newbie Questions
Old Mar 4, 2013 | 12:47 AM
Marfyyyy's Avatar
I have an 03 g35 coupe Manuel. I want to get aftermarket LED headlights that cost 350 on eBay but it says that it's only for OEM headlight or something. How can I know I have OEM manufacture on my car? It hasn't been upgraded from the only previous owner or anything everything's.
Old Mar 4, 2013 | 02:15 AM
Xet's Avatar
Xet
Huh? If you, nor the previous owners have changed the headlights on the car they are oem. If you're buying an aftermarket entire headlight replacement it wouldn't matter anyways since you are going to be switching them out.
Old Mar 4, 2013 | 03:11 AM
dukehotty's Avatar
Hello Manuel, the aftermarket lights should fit on your car if they are made for it. You just take the old ones out and put in the new ones. You could probably sell your old ones pretty easy. Which lights are you going to get? Copy/Paste the ebay link so we can see them.
Old Mar 4, 2013 | 03:22 AM
Marfyyyy's Avatar
Yeah these are it http://item.mobileweb.ebay.com/viewitem?itemId=140747190927&index=0&nav=SEARCH&ni d=02337016944
And I meant to say my car is stick Manuel not my name lol
Old Mar 4, 2013 | 03:29 AM
Marfyyyy's Avatar
How can I make my shifter less rough to shift??
I have an 03 g35. It's all clean title and wel maintained but its really rough to shift with it. I bought a short shifter hoping it can make it shorter obviously and smoother but its only a tad but better and I hate it cause it slows my timing cause of the roughness. Is there any solution that I can have a smooth way to shift gears?
Old Mar 4, 2013 | 03:32 AM
Marfyyyy's Avatar
How can I make my clutch pedal less harder to push?
I have an 03 g35 stick and my clutch pedal is pretty hard to push. It's been in well maintained and has 99k miles. Is there any way I can make it less harder to press?
Old Mar 4, 2013 | 04:12 AM
350GT_'s Avatar
Check that DIY thread that I posted in one of your other threads. There's bound to be something related to that in there.
Old Mar 4, 2013 | 04:31 AM
dukehotty's Avatar
Those lights will fit your G35. It says something about needing additional wiring for the "Halo" so I don't know what kind of wiring they mean. Either way, they should work just fine on your Manual G35
Old Mar 4, 2013 | 07:02 AM
SAMzG35's Avatar
G35
VIt's manual not Manuel lol
As for the headlights I would recommend going with 06+ projectors. They are much cleaner and serve a much better purpose.
Most aftermarket headlights leak condensation inside, have a horrible cutoff line, look shiiit. Also many of them are halogen, so you're actually downgrading. And the ones that take HIDs usually have H1 bulbs which aren't even that great.
Save up for a decent mod, don't rush and by POS parts just to make your car look fancier.
Nice > rice.
Old Mar 4, 2013 | 11:45 AM
Xet's Avatar
Xet
Our cars are known to be hard to shift smoothly, mostly due to the high engagement point of the clutch. Some claim that the rjm clutch kit allows you to shift smoothly more easily, but besides that it is really just learning how to shift on our cars better.
Old Mar 4, 2013 | 12:04 PM
06G35Coupe94's Avatar
Don't get that eBay crap. Get 06+ oem projectors
Old Mar 4, 2013 | 12:19 PM
partyman66's Avatar
Do you mean that the car bounces a lot when you shift gears and let the clutch out.... or do you mean that moving the gear lever through the gears is notchy and not smooth?
Old Mar 4, 2013 | 12:23 PM
Marfyyyy's Avatar
Notchy and not smooth.
Old Mar 4, 2013 | 01:55 PM
SAMzG35's Avatar
G35
I bought this over a year ago. Well worth every penny.
http://www.rjmperformance.com/350z--...edal-kits.html
Old Mar 4, 2013 | 02:28 PM
maclovio's Avatar
when was the last time you changed trans oil?
