Help with a/c please!
Old Mar 16, 2013 | 06:36 PM
Vjuice's Avatar
Hello everyone i just replaced my a/c compressor. Other one had a bad clutch.... But now my a/c clutch wont activate??!? I put freon in it and oil as well. Did i miss anything? I live in hot *** phx so i need it fixed asap. Thnks everyone!
Old Mar 16, 2013 | 06:40 PM
6mtg's Avatar
Did you over service or under service the compressor? And not to offend you but did you hook all the wires.back up
Old Mar 16, 2013 | 06:42 PM
Vjuice's Avatar
I put about 4-5 ounces of oil and about 19ounces of freon and yes i did but i think i will re check i highly doubt it though
Old Mar 16, 2013 | 06:45 PM
6mtg's Avatar
Ok cool. Did you by chance vacuum the old freon out before you serviced it? Ive had compressor's that are over serviced not come on
Old Mar 16, 2013 | 06:47 PM
Vjuice's Avatar
That i did not do i assumed once all the pressure was out it was empty?? Simce the compressor did not have anythn in it ... Is that somethn i can do at home
Old Mar 16, 2013 | 10:38 PM
Vjuice's Avatar
Still no solution this suks!!!
Old Mar 16, 2013 | 10:43 PM
Night's Avatar
was it a used or new compressor you put in? i have dealt with my compressor before maybe the sensor went bad
Old Mar 16, 2013 | 11:46 PM
Vjuice's Avatar
Used with only 40k miles. But tested and works. And what sensor?
Old Mar 17, 2013 | 12:17 AM
6mtg's Avatar
You can do it at home but you need the vacuum pump but .i recommend just taking it to be serviced . Its alot easier.
G35Rican
Jul 31, 2024 01:37 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
JLee301
Sep 25, 2015 08:46 PM
mattdg35
Sep 14, 2015 11:28 AM
