Car slow to crank??
Old May 9, 2013 | 05:57 PM
GR6RR's Avatar
I think when my battery went bad, one or two of the things on my speedo was acting up. needle pointing the wrong direction or something.. i forgot, its been awhile.
Old May 16, 2021 | 04:42 PM
53G50's Avatar
Why carbon fiber hood and trunk adjustable coilover suspension
[QUOTE=JaxBeQwik;6744596]So I had an issue of the car being really slow to start, like the battery was drained down. I hooked it up to my battery charger that usually indicates if I have a bad battery or not, and nothing. Charge was at around 13 volts. The charger would take it up to like 15.2 and stop like it should, but the battery would still be around 13 volts. Car started right up...
Now several days later it starts getting slow to start again. Pulled off at a gas station to fill up and it completely was dead, maybe turned over twice then nothing. No clicking heard.
Got a jump(now I have to take my cluster out and fix the gas needle) STOP RIGHT THERE You don’t need to take the whole gauge cluster out to flip the gas needle around just use a strong magnet when the key is in the off position
Old May 16, 2021 | 04:48 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
The needle can't flip in this car, it's got limit stops on both sides. He was probably fixing a stepper motor or something unrelated to the original post.
As for the original post, scroll down a few posts and you'll see he fixed the issue 8 years ago, it was a dead batter.
chinee
Jun 10, 2024 07:48 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
kenthung
Jul 21, 2015 05:56 AM
cyrus32
Jul 18, 2015 06:22 PM
