Rear end thump noise regular??
Old May 30, 2013 | 11:07 PM
ChancesLife's Avatar
So im new the "G" world coming from a honda background I decided to step it up. Well I recent bought an 05 6mt and and have been getting a Thump sound from the rear of the car when I put the car into 1st there a light thump and you can sorta feel it is this regular? would appreciate the advise.
Old May 30, 2013 | 11:43 PM
cheese20323's Avatar
Possibly the driveshaft... I have one for sale.
Old May 31, 2013 | 12:37 AM
God I hope not!
Old May 31, 2013 | 12:52 AM
LSGoose's Avatar
Have you checked to see if your diff bushings are shot? You'll see silicone running down the back of the diff cover if they're bad.
Old May 31, 2013 | 09:14 AM
LoSt180's Avatar
+1 on checking bushings. Thunk noise on launch is typically a mount or bushing.
Check the rear diff bushing first, should be pretty obvious if it failed because it's filled with goo and leaks down the diff cover. I also have a 240SX and that thunk noise can also be bad sub-frame bushings. I don't think the G is old enough to have that problem, and maybe that gooey diff bushing saves the subframe bushings from going bad.
Mine failed recently, here's what it looks like:
Old Jun 1, 2013 | 09:05 PM
a471133's Avatar
Might be the rear axle click/thump. As above, check the bushing first cause its easy. After that look up the DIY axle click fix on this site.
Old Jun 2, 2013 | 07:22 PM
Hey guys thanks for the advice I havnt had time to get it on the lift and check it out but yes I get the thump noise when im going in to gears more so when im steping on it and changing gears soon as I let off the clutch and accelerate it happens also dont know if it also has anything to do with slight vibration when im at low rpms 1-21/2k
Old Jun 2, 2013 | 09:34 PM
04g35mt's Avatar
mine does it too, im gonna check it out
Old Jun 3, 2013 | 02:42 AM
TTBUILTG's Avatar
plus 1 on bushings/seals. Is it clicking as well? Might be bad wheel bearing. Or also depending if the previous owner never changed the suspension it could be really worn struts that are bottoming out. repost when u find out what it was for future people searching this problem
Old Jun 3, 2013 | 08:36 AM
Blue Dream's Avatar
I drove ttrank's car solo
The axle click issue is just that, a clicking. There's no thump involved so I doubt it's the issue here.
Old Jun 3, 2013 | 01:10 PM
JKL1031's Avatar
I get that from time to time. Ur diff bushing isnt necessary lily worn to be replaced, but ur synchro is hanging up time to time. Does it clunk between shifts? I get a lil thub on hard 1st-2nd but its not bad to warrant a replavement. My 240 even did it.
Old Jun 3, 2013 | 02:46 PM
No clicking and yes clunk between shift mainly all gears even when im stoped when I engage the clutch and throw it into gear "clunk"
Old Jun 3, 2013 | 03:52 PM
Ok guys sorry to give you the run around im in the military and in between getting new orders and finishing up training I dont have time to mess with my car a lot so today I checked it outvagain and sorry its not coming from the rear end its coming from the engine bay ill paint the picture to see if this help car is at idle I engage clutch let off very quickly than slight "thump" next engage clutch put the car into first than back into neutral let off clutch quickly louder "thump" if i let off slowly nothing happens only when I do it quickly so it also happens when im driving and shifting fast so in other words anytime I come off the clutch fast I get this noise whitch leads me to now believe its my clutch anyone else expiring the same problem? Sorry again for the run around
Old Jun 3, 2013 | 04:08 PM
LoSt180's Avatar
Mine will make that thunk noise and rattle a little bit if I drop quickly in neutral. It's normal. Our cars just have noisy clutches.
Since you just got the car and aren't used to it yet, you might need to keep an eye on it in case it's something else. But loud flywheel and clutch noises are normal on these cars.
Old Jun 3, 2013 | 05:27 PM
I hope your right man thanks for the advice and yeah mine will rattle a bit at idle untile I engage the clutch than it goes away
