FUEL CUT RPM 6mt
Old Aug 10, 2013 | 03:30 AM
ARETHT3's Avatar
FUEL CUT RPM 6mt
Hi guys did a search couldn't find much. i have a 2003 coupe 6mt revs to 7200 rpm is this normal.? Im suspect as to if its had a re flash. It has a kakimoto exhaust, kintex plenum and earthing kit and pod and intake tube....
Almost if not as quick as my r33 with 10psi
Old Aug 10, 2013 | 09:48 AM
jookyshank's Avatar
I haz hugz to givez
Hold the cruise control "set" switch down (accel/deceel) then simultaneously push the cancel button once, then release both...
If your "set" light on your dash flashes once you may have an Osiris tune on the car. Or go to an uprev garage (member's house with a tuner kit) and plug in and it will tell you
(you may try the same step but push the cancel button three times then release both...if it's Osiris it will flash the set light on the dash 3 times...don't leave it there but at least you'll know the light flashing is indicating map changes and not some lucky random set light flash)
I'm not sure how to check for other engine management software.
Old Aug 10, 2013 | 01:40 PM
seymore4's Avatar
m56
Old Aug 11, 2013 | 12:08 AM
jookyshank's Avatar
I haz hugz to givez
^^showoff
Old Aug 11, 2013 | 01:11 AM
ARETHT3's Avatar
and if i dont have cruise control?
Old Aug 11, 2013 | 01:31 AM
jookyshank's Avatar
I haz hugz to givez
...then you don't have G....?
Old Aug 11, 2013 | 08:28 AM
Blue Dream's Avatar
I drove ttrank's car solo
Then you most certainly don't have the Osiris tune.............
jilljann1
Jul 21, 2020 08:12 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
Rhinos7777
Sep 6, 2015 05:36 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
