Rattling When Accelerating
Old Aug 10, 2013 | 09:36 PM
CodyJBynes's Avatar
Good evening,
I have an '06 5AT G35 coupe, with 54K miles, and I started hearing this noise when I'm accelerating relatively hard. I thought it was the heat shield but I put it on a lift and nothing is loose..
It happens at around 2-3k RPM in 1st, 2nd and 3rd gear, and it happens mainly in drive, but when I'm in manual mode it won't happen unless I really step on it.
Can anyone throw out a few ideas?
Thanks in advance.
Old Aug 11, 2013 | 12:26 AM
TORETTO's Avatar
do you have a pet rattlesnake
Old Aug 11, 2013 | 02:29 AM
dukehotty's Avatar
My 06 5AT had a short rattle at high RPM's and it ended up being something with the cat. It was replaced under warranty.
Old Aug 11, 2013 | 07:45 AM
Texasscout's Avatar
If it's not "detonation" from bad gas/timing, then you most likely have a heat shield loose.
Old Aug 11, 2013 | 11:59 PM
James86's Avatar
Originally Posted by CodyJBynes
Good evening,
Thanks in advance.
check your cats . I had the same problem and that's what it was
Old Aug 12, 2013 | 12:52 AM
Stillen06coupe's Avatar
cats or knock
Old Aug 12, 2013 | 02:12 AM
livinglegend's Avatar
Like said. most likely some component in the exhaust system. nothing may seem loose to the eye, but even if the head shields are tight, the baffling/material in the cats/resonators/mufflers/flex-pipes can wear out and come loose and start to make noise as well.
Old Aug 15, 2013 | 01:00 PM
alxn91's Avatar
Agree, had the same problem and ended being a bad cat. Got it replaced under emission warranty. If you want to make sure take it to a muffler shop and they will tell you if it is a loose component from the exhaust.
06g35
Feb 14, 2022 05:59 AM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
TNRocker
Sep 21, 2015 08:36 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
socaldavid
Sep 5, 2015 04:35 AM
