Interior replacement
Old Aug 15, 2013 | 10:24 AM
Ginger Bread's Avatar
Hey guys,
I found an 05 g35 coupe local that has the options i want and decent milage. The issue is the previous owner had some hackjob sound system in it so it needs, essentially, a whole new interior. It needs, carpet, door panels, back seat/console, dask kit/trim. I looked at the car 4 months ago and the price hasnt changed. Can anyone guestimate how much an interior swap like this may cost so i can try to figure out what to offer him to make it worth it.
Said car
http://used.carwayonline.com/m/detail/used-2003-infiniti-g35-ft-lauderdale-florida-a2177249.html
Old Aug 15, 2013 | 10:34 AM
broke_as_ajoke's Avatar
Are u going to replace the parts or have them redone. If u are going to replace them with all need OEM parts u are looking at about 2 or 3 grand..
Old Aug 15, 2013 | 10:55 AM
The doors have holes cut out of them for speakers and grilles covering the holes so need new door panels. The rear bench seat is broken on the passenger side so that needs replaced. The dash is hacked/broken from the radio install so that needs replaced. It all needs to be replaced. If anything is repairable i can cover that but what i listed is too far damaged to be fixed.
Old Aug 15, 2013 | 11:08 AM
well, what I would do is search the forum to see if anyone is parting out their interior. If that doesn't work check the junkyard for a damage G35 and if no luck there u can then order the parts from any OEM ifiniti parts dealer, but U will probably be looking at anywhere between 3 to 5 grand.
Old Aug 15, 2013 | 11:25 AM
I wouldnt be opposed to going to black either if it worked out.
Old Aug 15, 2013 | 11:30 AM
U can check this guy out, this way u can get some prices:
Oh by the way.. the place around the radio/ac is about 300 bucks
Hello G35driver members! My name is Phil and this thread is for you to get quotes for OEM and aftermarket parts.
Please provide your VIN# and zip code, that way I can provide you an accurate quote and availability.
Feel free to stop by our show room, PM, call or leave a message here and I'll reply in a timely manner.
(714) 650-8586
OC Infiniti
15550 Beach Blvd.
Westminster, CA 92683
Parts Dept hours
M-F - 7:30 am - 7:00 pm
Sat - 8:00 am - 4:00 pm
Sun - CLOSED
__________________
WWW.OCINFINITI.COM
LNGUYEN@OCINFINITI.COM
(714) 650-8586
Old Aug 15, 2013 | 05:46 PM
Only problem with ^ is that he couldnt be any further away from me so shippong will prob be a fortune.
Old Aug 15, 2013 | 06:34 PM
Lone Wolf's Avatar
Your better off finding another G in my opinion. Interior pieces for our cars are expensive and you will be charged an arm and a leg if you have the dealer do it. But, if you really want the car be prepared to spend some bookuu dollars. I would say around 3k based on what I've had replaced inside of my car.
Old Aug 15, 2013 | 10:53 PM
wallofgrath's Avatar
Find a totalled G35 local to you, salvage yard. Should only cost a few hundred dollars + install.
Old Aug 15, 2013 | 11:03 PM
Knightstiq's Avatar
I dunno, if they treated the interior like that, how did they treat the rest of the car?
There are lots of options out there, if you can afford to wait til you find that one that makes you warm and fuzzy, you may want to take a deep breath and think about it.
Just sayin
Old Aug 15, 2013 | 11:21 PM
rsingerG35's Avatar
I'd avoid because who knows what kind of hack job was also done with the wiring. If you see a car in this shape it probably wasn't cared for at all. I'm sure you will run into underlying problems also.
Old Aug 16, 2013 | 12:08 AM
Thats another concern. It runs and drives fine but i do worry about the integrity of any maintainance or repairs done on it. I think i could make it worth it if he lets me have it for 8k.
Old Aug 16, 2013 | 12:12 AM
rsingerG35's Avatar
If your serious get a car fax report.
derres
Aug 28, 2015 03:27 PM
s8n
Jul 31, 2015 01:37 AM
s8n
Jul 30, 2015 04:47 AM
