clutch makes a noise when turning off engine
Old Sep 4, 2013 | 07:09 PM
Kenneth Tran's Avatar
i have a 06 manual coupe and i was wondering if there is something wrong in my car. When i shut off my car, my clutch makes like a ratting of some sort. anybody know about this?
Old Sep 4, 2013 | 07:42 PM
saywat?'s Avatar
how do u kno its the clutch?
Old Sep 4, 2013 | 07:50 PM
because it only makes the noise when i release the clutch.
Old Sep 4, 2013 | 07:51 PM
saywat?'s Avatar
and it doesnt do it during normal driving?
Old Sep 4, 2013 | 07:55 PM
not that i hear of. i only hear it when i turn off the engine.
Old Sep 4, 2013 | 07:56 PM
saywat?'s Avatar
weird.
Old Sep 4, 2013 | 09:30 PM
stalliko's Avatar
It's normal, the shaft doesn't have a bearing on the end so when you shut it down your hearing it rattle while it winds down. Mine does the same, so do my buddies
Old Sep 4, 2013 | 09:35 PM
JC-RH's Avatar
Yes. It's normal. I just hold down my clutch pedal while I shut down the engine. No big deal.
saywat?'s Avatar
after thinking about it i dont ever still have the clutch pressed while turning off the car. so i guess its never happened to me. when i turn off my car the clutch pedal has been release way in advance when the engine is still running. seems strange to release clutch after turning engine off
Old Sep 4, 2013 | 10:48 PM
CMB281's Avatar
I think my '05 6MT has this same problem and I've always wondered what exactly it was. I just assumed it was clutch related since it wouldn't make the noise if I was holding in the clutch when I was turning off the ignition. Good to know it seems like a common "issue".
Old Sep 5, 2013 | 10:27 AM
thanks everybody!
Old Sep 5, 2013 | 03:13 PM
JKL1031's Avatar
shutting it down with clutch in here too. I didnt start a new thread to figure it out.
Old Sep 5, 2013 | 04:19 PM
Ejgold55's Avatar
dual fly wheel chatter...hold the clutch in when you turn off the car to eliminate the noise, or if you don't it doesn't matter, it will not hurt anything.
rezendvous420
May 31, 2020 01:26 PM
joedaddy1
Jul 28, 2015 02:58 PM
cyrus32
Jul 18, 2015 06:22 PM
Thaaa_king
Jul 18, 2015 05:56 PM
