VDC Off, Slip, and ABS lights on, can't shift
Old Sep 22, 2013 | 12:31 PM
dreamreality's Avatar
Hey guys,
Woke up this morning and tried to put my '03 auto coupe in drive and it's locked. Stepped on the brakes and the VDC Off, Slip, and ABS lights come on. Turn the car off and on again, lights are off, but come on the moment I step on the brakes and still won't allow me to shift.
Any idea what the issue may be? Thanks.
Old Sep 22, 2013 | 02:19 PM
Urbanengineer's Avatar
Check your master cylinder? N clue bud.
Old Sep 22, 2013 | 02:31 PM
redonblack35's Avatar
What he sed^
Old Sep 22, 2013 | 07:16 PM
Blue Dream's Avatar
I drove ttrank's car solo
You can try to use the shift lock to release the transmission. Also check the brake fluid level, might be low with that combination of lights on.
Old Sep 23, 2013 | 08:01 AM
Shariq Ahmed's Avatar
you most likely blew a fuse, had the same problem and after i replaced the fuse it was all good.
Old Sep 23, 2013 | 08:22 AM
Blue Dream's Avatar
^^Post up what fuse you replaced so the OP knows where to look please.
Old Sep 23, 2013 | 08:57 AM
I honestly dont even remember which fuse it was, it was the fuse box located inside on the driver side, there should be a diagram on the cover of which fuse is which.
Old Sep 23, 2013 | 12:16 PM
That's good to know. I will give it a shot after work today. Hopefully I can dig up a diagram somewhere.
Thank you! Hope this solves the issue.
Old Sep 23, 2013 | 01:02 PM
JKL1031's Avatar
You may have gotten hit with one of those things from fast and furious that disables your ECU.
Old Sep 23, 2013 | 10:14 PM
So, it the brake light fuse was blown. Changed it and the car worked fine and I was able to shift out of park and drive around. Halfway through the drive, the lights came back on. I parked and wasn't able to put it back into drive anymore.
Checked the fuse and it was blown. Tried one more fuse and this one blew up too.
Any idea what may be causing this?
Old Sep 24, 2013 | 06:21 PM
Just took it to the shop. Apparently one of the wires from my spoiler tail light went bad which was causing it to short the fuse every time I step on the brakes.
Getting the issue resolved now. Thanks for all the help!
Old Oct 1, 2013 | 06:51 PM
Golfer622's Avatar
This happened to me twice on my '04, about 3 months apart. A brake light fuse blew both times. After each time, the dealer found a problem in the wiring harness and fixed it. Hasn't happened again since, and it's been a year.
You can drive the car in this condition by sticking something like a skinny screwdriver into the shift lock hole, which will allow you to shift. Unfortunately in my case, no brake lights, and I think I almost got rear-ended 3 times on the way to get it fixed.
Old Jul 1, 2023 | 03:08 AM
VCOBI's Avatar
G35 Coupe
I had the same issue and I was able to fix the problem by replacing fuse #20. I googled the web for the diagram.
Mry
Mar 3, 2023 01:03 AM
SiMpLyMoDiFiEd
The FX-Spot
Dec 2, 2021 04:35 PM
mjfenix
Aug 17, 2017 05:49 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
