Smoking from exhaust and smells like oil
Old Oct 19, 2013 | 06:04 PM
needforspeed's Avatar
any input would be appreciated. 2 weeks ago i had to change my camshaft position sensor, but before i changed out my sensors i made a mistake by adding quart and a half of oil without checking the level and the smoking problem started. i've chaged the oil about 50miles ago and chaged pcv valve 2day ago, but still have smoking issue. thank you in advance for your time
Old Oct 19, 2013 | 07:13 PM
Blue Dream's Avatar
I drove ttrank's car solo
My guess is you overfilled the oil and somehow it got somewhere it shouldn't. Not sure why the exhaust would smoke but hopefully someone else will chime in.
Old Oct 19, 2013 | 09:38 PM
Stillen06coupe's Avatar
If it's just an overfill issue, the smell will eventually go away. Give it time. If it doesn't go away, you could have bad valve stem seals
Old Oct 21, 2013 | 08:01 PM
Thank you guys for the valuable inputs. I'll play the waiting game for now and post an update after I drive about 500miles more.
Old Oct 21, 2013 | 09:12 PM
saywat?'s Avatar
if its over filled why not do a drain and fill ?
Old Oct 21, 2013 | 09:16 PM
danoman32's Avatar
^ He already changed it.
Old Oct 21, 2013 | 09:21 PM
saywat?'s Avatar
oh ok. misread
Old Oct 21, 2013 | 09:27 PM
danoman32's Avatar
Oops, wrong thread. Good luck with the problem. BTW, do you always add a quart and a half with out checking it first? Lol
itztwinki3
Lights
Oct 15, 2015 04:38 AM
Eomfd
Aug 29, 2015 12:42 AM
Terry_G35
Aug 4, 2015 02:38 PM
newg37
Jul 26, 2015 09:32 AM
