Loss of oil on my '05 coupe
Old Nov 8, 2013 | 01:38 PM
JKL1031's Avatar
How long have you had the car? U need to use conventional oil, it will burn off slower than synthetic. Pennzoil gold high mileage. It is unfortunately just a VQ problem.
Old Nov 8, 2013 | 06:03 PM
irishsig's Avatar
I can't comment personally on the pros and cons of using synthetic on the DE engine because I never have,
but after they replaced my short block (due to the dreaded OC issue) the 2 techs from Infiniti suggested sticking with conventional oil.
Apparently they observed many instances of more oil consumption after switching to synthetic.
Old Nov 8, 2013 | 07:50 PM
JKL1031's Avatar
Synthetic molecules are more like water so they slip through where ever its going out.
Old Nov 8, 2013 | 11:38 PM
jookyshank's Avatar
I haz hugz to givez
https://g35driver.com/forums/engine-...ption-tsb.html
here is a grip of data on the OC issues. My '05 coupe had "mid grade" OC and once the shortblock was replaced, it consumed ZERO oil for the rest of the time I had it...The ring replacement worked in my case
Old Nov 9, 2013 | 12:10 AM
bythabay's Avatar
I had an 05 rev up that I owned since new and it consistently used about 1qt in about 7k miles. I recently picked up an 03 z motor, vq35de non revup and it hasn't burned a drop in the 7k that I have driven it. This used motor had about 70k on the clock, I guess I got lucky.
Old Nov 9, 2013 | 12:40 AM
jookyshank's Avatar
I haz hugz to givez
'05-'07 "Rev Up" motors were the highest rate of failure group so your '03 is statistically safer on the OC front.
Old Nov 9, 2013 | 12:41 AM
bythabay's Avatar
I guess I have the best of both worlds. That 03 motor went into an 05
Old Nov 9, 2013 | 10:33 AM
JKL1031's Avatar
I wud have taken 1qt. in 7k. and ud better stop running 7k intervals. Id go at most 4.5
Old Nov 9, 2013 | 07:48 PM
HereKittyKitty's Avatar
I would of bought an '03-'04, to remove the aggravation that I have been thru. But I knew the risk.
I'll just monitor the oil, but let it be known me gots a newly rebuilt engine!
R350k5
Oct 1, 2015 08:41 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
lemmy999
Jul 25, 2015 12:13 PM
ClwMike
Jul 23, 2015 12:55 PM
