Can't find many with this problem.
Old Nov 12, 2013 | 07:31 PM
Thelooker's Avatar
Okay so my rear break lights work, blinkers work, hazards work but while I'm driving the rear running lights are not on what's so ever... No fuses are blown inside the car or under the hood...
Old Nov 12, 2013 | 07:49 PM
WhosUrBuddiee's Avatar
Search the service manual. Also there are 3 different fuse blocks, did you check them all?
http://psedog.com/cars/fsm/g35/coupe/2004/lt.pdf
Old Nov 13, 2013 | 06:03 PM
Thelooker's Avatar
Yeah I did not a single fuse out. Took it to Nissan they said it would 136 dollars a hour to them to figure out what's wrong.
Old Nov 13, 2013 | 07:41 PM
Get a multi meter, start at the bulb socket, follow the electrial diagram checking each point, until you get back to the fuse block. You will find the problem.
Old Nov 13, 2013 | 11:33 PM
Thelooker's Avatar
Thanks! Will try it tomorow!
Old Nov 22, 2013 | 09:34 AM
infinitidude's Avatar
The fuse for the tail lights is in the IPDM-ER which is down behind the battery(has a black cover on it) I believe the top left fuse is for the tail lights.
mike730
Jan 12, 2018 04:25 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
All G'd Up
Aug 29, 2015 12:40 AM
si_driver
Jul 14, 2015 12:29 PM
