POP noise right after starting
Old May 4, 2003 | 05:10 PM
DallyCurtis's Avatar
I just got the car a few days ago...and I noticed a couple of days after getting it .... there is a slight POP type noise ...seemingly a charge type sound outta the speakers.
It seems to happen intermittently with the radio on or OFF.
Anyone else?
Old May 4, 2003 | 06:03 PM
ryoken's Avatar
Re: POP noise right after starting
Does it happen when you first start moving, and hit about 5-7mph? If that's the case, it's probably the ABS self-test.
Old May 4, 2003 | 06:20 PM
NOpe.... It seems to happen right after the key is turned over. Right when you turn it over ... it goes ..naa annanananannanan
VRooonmmmmmm
half a second
POP
with or without the stereo on and seems to come outta the speakers, kinda like a old record player skipping or someone droppin the needle on a record.
I dunno .... it doesnt happen all the time.
later bro
Old May 4, 2003 | 08:40 PM
RamboRami's Avatar
G35driver.com Moderator
a possesed G? hmmm, do you live by an old native indian burial ground?
<font color=green>-Ramb0</font color=green>
Old May 4, 2003 | 09:11 PM
Meradin's Avatar
I have a similar sound but it doesn't come from the speakers. It sounds to me like the ac compressor click or poping on after the engine starts.
G35 Coupe 6spd w/ PP & Aero
DG w/ Graphite Leather
Old May 4, 2003 | 09:23 PM
MajinNav's Avatar
Does that ABS Self Test sound like a little whir?
Old May 4, 2003 | 11:19 PM
BMW3toG35C's Avatar
From the G35 owner's manual:
"The computer has a built in diagnostic feature
that tests the system each time you start the
engine and move the vehicle forward or in
reverse at a slow speed. When the self-test
occurs, you may hear a clunk noise and/or feel
a pulsation in the brake pedal. This is normal
and is not an indication of a malfunction."
Might be what you're hearing...
Old May 5, 2003 | 07:37 AM
It happens when I start the car ...INTERMITTANTLY .. in a stop position...
you know how the dash lights come on automatically right away . it happens right then seemingly like a pop out of the speakers .
SH*T
I say intermittently because, it happens say in the morning ... wait like 2 minutes of running and restart the car and it DOES NOT HAPPEN.
SH*T
not a big deal ... but electrical issues are real potential problem.
Thanks fellas
Old May 5, 2003 | 11:27 AM
I can't beleive I am the only with this.... what the hell....
I was afraid of this ....
what a sh*TTer.
Old May 5, 2003 | 07:00 PM
gsg's Avatar
gsg
FYI: The break adjusting is a mechanical clunk sound. It is not an electrical pop or click type sound.
Old May 5, 2003 | 10:23 PM
Rockman's Avatar
My 2k Maxima does that.
Rockman - DG/G 6MT Coupe w/prem. (on order)
Old May 6, 2003 | 11:52 AM
Well, I taking the car over to the dealer today....
It was raining yesterday and it did not do it as loud ...it happened evertime I restarted but like I say... no even half as loud.
Did it this morning in the underground all dry down there as loud as it ususally does ... but restarted it and nope. Mind you if I go start it now 5 hours later, I'm sure it'll happen.
What the hell is wrong with it ... how could my ride be the only one.
I got a bloody lemon, I'm pissed off. I just wanna start it up and not have to worry.
geesus
Old May 6, 2003 | 06:10 PM
Growler's Avatar
Hey Dally..........I believe the hollow sounding POP noise you hear from the rear of the "G" is coming from under the back seats. The fuel tank is located there...I suspect it is the fuel pump pressurizing. My Maxima used to HUMM for second while the pump was charging. The POP I get is intermittent, that is it's loudest when the car has sat overnight. First thing on startup as soon as the key is turned, microseconds before the engine starts is...............POP!!!!
Don't worry about it...I've had it since day one..4 months and 2000 miles ago.
Growler
Old May 7, 2003 | 11:00 AM
hmmmm ... close but no cigar.
this is the event chain
put in key (obvious)
turn over
nnnnananannanan
cluster lights come on (POP)
vrooom from mufflers
idles out normal
restarting may cause pop or may NOT
BUT
I did this as a test .... I turned the key half way till the cluster lights come on and the fuel is primed up... for a second or two ... and then start it ...
where as the cluster lights will turn off during starting and then back on till start up
VROOM
and IT DOES NOT POP
I dunno.
Old May 7, 2003 | 01:49 PM
geezer's Avatar
dally:
funny thing is, everytime I thought something was wrong with my G, I thought -"uh,oh, here is the problem I go to the dealer for" Inevitably it was something I did or it was normal. I do not know if the G can be a lemon! Buck up!
