What rails are these?
Old Dec 12, 2013 | 10:25 AM
dinojuice's Avatar
Right under side of 04 g35 coupe.
What part Number is this should I be worried, no leaks but I do have rough idle nd breaks problems.
Old Dec 12, 2013 | 11:59 AM
Mustang5L5's Avatar
I'm going to guess here as i don't feel like pulling up the FSM at the moment,
But fuel and brake lines. Looks like crush damage to at least two of them.
EDIT: looked through the FSM. They don't show line routing, but my guess is more than likely accurate. 2 fuel lines (feed and return) and 2 brake lines for each caliper out back.
Old Dec 12, 2013 | 12:47 PM
murphaayyy's Avatar
The smaller lines should be your break lines. You need to get that fixed, definitely a problem. It was also explain your brake problems as you might have lost fluid. Is your reservoir for the brake fluid low/empty?does the peddle feel really soft and not want to stop the car? Definitely not safe to drive with no rear brakes.
Sepsis
Feb 12, 2020 02:05 PM
StreetStandard
Accessories-Vendor
67
Aug 15, 2016 02:45 PM
CrazyMike
Apr 16, 2015 10:20 PM
GurgenPB
Forced Induction
Sep 8, 2005 12:03 PM
GurgenPB
Forced Induction
Jul 18, 2005 05:14 PM
