Coupe G35 04 / code P0302 Number 2 Cylinder Misfire Detected
Old May 6, 2014 | 01:53 PM
IVAN S.'s Avatar
Hello Guys, I recently notice a Lack/loss of power on my engine or some short of shakiness when I stop and or in Idle... so i read the code on my car (with a pocket Reader) and gave me the code P0302 Cyl #2 Misfire~ so i when and replace the all 6 spark plugs with Laser NGK ($13.99 e/a) and also replace the coil in cyl # 2 ($95 autozone) although the problem still the code hasn't gone away nor the staleness or shake any other ideas ?
Old Oct 4, 2020 | 12:33 AM
Nukacola's Avatar
Infiniti g35 04 has a few mods
Coupe G35 04 / code P0302 Number 2 cylinder misfire Detected
hello, I know it’s been a while since you have posted this.. but did you found out what the misfire was ??
Old Oct 4, 2020 | 10:34 AM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
I'd check the coil pack harness for damage, also ring the wires out back to the ECM to make sure there isn't a broken wire. Schematics are in the FSM section EC - Engine Controls under that DTC code.
Au79
Apr 24, 2020 09:13 AM
Cesar023r
Jan 7, 2013 12:56 PM
Gossmerjr2
Oct 26, 2012 04:03 AM
THE-G35
Aug 17, 2011 08:12 AM
High3nd_SD_g35
11
Jun 16, 2008 04:01 AM
