Trip Maintenance and Fluids
Old May 18, 2014 | 08:47 AM
gmoney35s's Avatar
Alright in a couple weeks i have to make a run up to Detroit from OKC by the time i get back itll be just over 100K on the meter so i was gonna have the tranny fluid changed out probably try and add the the Transgo shift kit while I am at now i know i need to use Nissan fluid for that my question is more along the lines if i have to use a special fluid for the rear diff and how much fluid do i need for it thanks in advance for the help
Old May 19, 2014 | 12:07 AM
coffeysm's Avatar
I used Mobil 1 75W-90 and about two bottles of it. Pop the fill plug first PRIOR to draining it also having a vacuum or pump device is a must!
Old May 21, 2014 | 08:18 PM
gmoney35s's Avatar
coffeysm thank you for the help on this did you flush it at all after the vacuum
Old May 21, 2014 | 11:29 PM
coffeysm's Avatar
When I say pump or vacuum I mean something to push the fluid back into the diff. I used a Motive power bleeder that I have, but you can pick something up for like 10 bucks. Just clean the drain plug off and you should be good.
Old May 22, 2014 | 12:07 AM
gary c's Avatar
If your trans is shifting like intended why waste your $$ on the Transgo kit? Changing trans/differential fluid is a good idea, don't forget to check your belts and do a drain/fill on your radiator fluid if it hasn't been done within the last year...Gary
Old May 22, 2014 | 01:07 AM
Eno's Avatar
Eno
Are you serious?
Marlin84
Apr 1, 2020 12:52 PM
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
