HELP ASAP !! Popcharger Cleaning
Old Feb 13, 2005 | 02:09 PM
axiochris's Avatar
Hey guys,
I am going to clean my popcharger today and had a question.
So once you clean it with 409 and rinse, then you put on the popcharger oil,
How long do you have to wait before you can put the popcharger back on the z tube. Do i even need to wait????
thanks guys
Old Feb 13, 2005 | 02:34 PM
Akb123's Avatar
I hope this isn't to late. I Just cleaned mine out the other night. I got home about 2am. Sprayed it cleaner, let it sit for about 5 minutes. Re-sprayed it with cleaner and then proceeded to rinse it out with the hose. I layed it in my garage for the night to dry. When I woke up the next morning, I put it outside for about an hour to let it dry some more. After the pop charger was dry, completely, I then re-oiled it and let it sit in the sun for about an hour. I wouldn't use the pop charger for at least 6-8 hours to allow all the water and moisture to come off of it. you dont want water in your engine.
Old Feb 13, 2005 | 02:43 PM
axiochris's Avatar
thanks man !
Old Feb 13, 2005 | 02:52 PM
Akb123's Avatar
Yeh no problem I would wait to do it at a time when you wont be driving for a while, like at night.
Old Feb 13, 2005 | 03:38 PM
Speedoholic's Avatar
G (enie) FUNK ERA
I think the best way to determine if your filter is ready to be used is by moving your finger over the filter. if you get oil moisture stuck to your finger, let it dry a bit more.
Old Feb 13, 2005 | 06:55 PM
escobar929's Avatar
if your worried about having to drive before its dry, just put your stock pieces on, it only takes 15 min.
Old Feb 13, 2005 | 08:49 PM
Vic's Avatar
Vic
by the way, how do you know if you put too much or too few oil on the filter? I have reoiled my popcharger, but still hesitate to install it again.. I'm just worried if I put too much or too few oil.
Old Feb 13, 2005 | 09:06 PM
Akb123's Avatar
It should be a light to dark blue color. It's hard to explain it, just make sure you have sprayed ever spot.
Old Feb 13, 2005 | 10:24 PM
kroams's Avatar
Do you only spray the outside of the filter?
Old Feb 14, 2005 | 01:03 AM
axiochris's Avatar
i think you are supposed to just oil the outside???
i havent done it yet..i didnt know you needed soo much time for it to dry. (i cant find my stock pieces)
btw...does a dirty filter affect perfomance. am i tripping or does my car feel a little slower now.
Old Feb 14, 2005 | 06:32 AM
neffster's Avatar
According to the K&N reoiling instructions a "dirty filter" allows for better air flow. (Sounds weird doesn't it). They recommend cleaning the filter every 50,000 miles, but they don't account for areas with a lot of construction, high pollen counts, etc...
I clean mine once a year and when I do I usually give it a 1-2 day wait before use. The cleaning is quick and easy. The air dry takes maybe 4-6 hours in the FL sun. The reoiling is the part where you want to be careful.
I reoil the outside of the cone filter only. From there let the oil absorb through the filter. When finished, stuff a lint free diaper rag inside of the filter and let it absorb the excess oil. After waiting over night take a paper towel and wipe the pleats on the outside of the filter and see how much oil, if any, comes off. If you touch the filter it should feel oily, but you should not visibly see any oil on your fingers.
It's a good idea to install the filter, drive for 15 or so miles and then take 2 minutes and inspect the inside of the intake tube. Just loosen the pipe clame around the filter base and slide the filter off. If there are any signs of oil inside of the intake tube, clean it out IMMEDIATELY and repeat the diaper rag and paper towel instructions above.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Duffy25
Accessories
Oct 12, 2015 01:45 AM
dcsbh1
Oct 1, 2015 03:15 PM
vamarris
Sep 26, 2015 12:56 PM
