engine will not turn over
Old Jul 9, 2014 | 07:19 PM
slim17265's Avatar
the gremlins are back
Having trouble with alarm/emobilizer...car will not start or turn over, no click. dealer checked says he has no clue...suggests I leave cars (probably with my visa card, ha ha) I had it narrowed down somewhat and disconnected battery overnite...worked for one day..the problem now seems to be involved with "FOB key. if I lock car with key it will not start..if I do not use fob it will start next time. I disconnected battery overnite this worked fine for two days and then left me stranded..
I have gone thru everything I canthink up, If I do get stranded I can deliberately cause the alarm to go off then key will work, not the fob.
today everthing works fine as long as I DO NOT LOCK CAR....VDC and slip light are present, dnk what that is or if that is causing the above problem
Old Jul 9, 2014 | 07:39 PM
iamthepaulrus's Avatar
Have you tried wirebrushing the battery terminals and connectors and/or changing the battery? Check this thread for suggestions...
https://g35driver.com/forums/g35-cou...-pls-help.html
Old Jul 10, 2014 | 02:45 AM
slim17265's Avatar
yes, that is the first thing I did
mtlruss
Dec 20, 2015 01:51 PM
Jiggerjuice
Oct 5, 2015 02:33 PM
andyg35c1
Aug 29, 2015 03:37 PM
Phenomenon9
Aug 9, 2015 01:34 AM
Terry_G35
Aug 4, 2015 02:38 PM
