Tail light fuse
Old Aug 20, 2014 | 09:51 PM
Evan.bullock's Avatar
Tail light fuse
I have a 2003 g35 coupe, and my tail/braking lights won't turn off. Was told it was the braking switch but could anyone tell me which fuse keeps them on? Any diagram I find online isn't helping. I'd need the diagram of the panel from the fuse box in the engine, which I can't find.
Old Aug 21, 2014 | 07:32 PM
wuzz-upp's Avatar
See the following diagrams in the service manual Pages, PG-4, PG-6, LT-135. Note that the fuse you are looking for protects other systems not just the tail light. If you remove the fuse, you will be disable-ling other systems. There is a small black rubber/plastic button on the brake pedal lever that actuates the brake switch. These are known to deteriorate and break off or fall off. Have you tried to depress the switch by hand and have some look to see if the lights go out?
Old Aug 21, 2014 | 07:42 PM
wuzz-upp's Avatar
BTW, it is Fuse #20, it is a 10Amp and it is located on the drivers side behind the L/H kick panel.
Old Aug 24, 2014 | 03:26 AM
Chantastic's Avatar
Try pulling the brake switch out and testing it like mentioned above. There are two switches on the pedal, I think the brake one is solid black (no brown on it). Anyway if you unplug the wrong one it really doesn't matter (just twist them to get them out). Plug them back in afterwards.
Old Aug 24, 2014 | 11:12 AM
wuzz-upp's Avatar
The two switches are typically the Brake light switch and the Cruise Control cut off switch.
It would be helpful for others in the future if Evan.bullock would give an update on what the fix was, hopefully he will.
Old Aug 25, 2014 | 08:56 AM
infinitidude's Avatar
The tail light fuse is in the ipdm/er behind the battery. It should be the top left fuse and it is also labeled on the lid as well when you remove it.
Old Aug 25, 2014 | 08:33 PM
wuzz-upp's Avatar
If you read the write up closer, his problem is with the brake/stop lights staying on. The stop light wiring diagram is on page LT-135, the fuse is #20, it is a 10A fuse and it is located where I previously stated. The fuse you are referring to is for the tail lights, wiring diagram is on page LT-149 & 150, that fuse is #75 and it is also a 10A fuse.
In any case, Evan has not responded so he probably got the problem fixed and forgot he asked for help. Maybe he will respond and bring closure to the thread.
Old Jan 29, 2023 | 06:12 PM
Gantert12's Avatar
G35 coupe
Tail light and DRL not running
Hey so I’m having trouble, I’ve checked the fuse and it was not blown. I did notice however that the main wires that plug into my headlights are ripped off. Would that have anything to do with my tail lights and DRL not running? Turn signal and brake lights still work.
Old Feb 4, 2023 | 03:20 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Turn signal and brake lights are completely separate circuits, parking lights is another completely separate circuit.
roboeclipse
Lights
Aug 13, 2015 10:45 PM
mcneil_g35
Lighting
Aug 5, 2015 01:09 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
