uprev maf gt
Old Oct 23, 2014 | 12:09 AM
es_bayy's Avatar
uprev maf gt
Will running the uprev gt maf on a NA car cause problems like: being too rich, cause shift point issues with the 5AT. I just had my vortech installed, however I took out the injectors and sc belt until I get a custom osiris tune. I left the uprev maf and I've been experiencing idle problems, and shift issues (hesitation).
Does anyone know or have any experience regarding running the uprev maf on a "NA" car? Will using the uprev maf over the stock maf cause issues with my transmission?
Old Oct 23, 2014 | 12:38 AM
herrschaft's Avatar
I'm fairly certain tuning is required for the car to run properly with the Uprev MAF. I would recommend throwing the stock one in for now.
Old Oct 23, 2014 | 12:44 AM
es_bayy's Avatar
Do you think that could be the issue with my transmission not shifting properly? Does the MAF even have an effect on the TCM?
Old Oct 23, 2014 | 01:05 AM
herrschaft's Avatar
I'm not a tuner so I can't go in-depth with it. You could PM member Seymore4, he should be able to give you an exact answer.
I don't believe I ever had an issue with the Uprev MAF on my car but when my tune/ECU wouldn't recognize an aftermarket TB I had issues with the idle and tranny shifts. I'm assuming it was the TB since I have never had issues with the MAF in the past. Took my car in to get diagnosed for that but I won't have an answer any time soon.
Old Oct 23, 2014 | 01:14 AM
es_bayy's Avatar
You never had any problems with the maf? Did you have a tune on your car while using the maf? I'm hoping it's just the maf and not like a vacuum leak..
Old Oct 23, 2014 | 01:28 AM
herrschaft's Avatar
I am tuned with Uprev but I'm not sure if my current problems are linked to the MAF or not. I would still contact Seymore4 first since he is a tuner that has experience with Uprev and their products and can probably save you some trouble.
KruZZe
Feb 27, 2023 05:04 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
vamarris
Sep 26, 2015 12:56 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
