Left HID side went out again lol 💩💩
Old Dec 13, 2014 | 11:26 PM
6SJ's Avatar
6SJ
Question Left HID side went out again lol 💩💩
its happened before but then it just fixed itself i guess. and now when i went to turn on the car the light is out again should i replace the ballast or can it be loose wiring or anything else? let me know. 👊👍
Old Dec 14, 2014 | 07:47 AM
Jonlex99's Avatar
Bulbs don't last forever....
Old Dec 14, 2014 | 04:04 PM
Void's Avatar
^^^ this lol probably time for some new bulbs.
Old Dec 14, 2014 | 04:38 PM
6SJ's Avatar
6SJ
lmao true i might as well upgrade to spyder hid lol thanks for the replies ��������������
Old Dec 14, 2014 | 05:43 PM
ScraggleRock's Avatar
Actually the bulbs last an incredibly long time, and ballasts go out very frequently. Its most likely your ballast. Take the ballast from your other light, plug it into the one that's not working and see if the problem persists. If it works, then its a ballast problem. If not, then its the bulb. I'll tell you tho, mines an 04 with original bulbs and I do a lot of driving in the dark.
Old Dec 14, 2014 | 09:42 PM
Urbanengineer's Avatar
No wonder your bulbs last so long.
You should consider turning on your headlights at night instead of driving in the dark.
Old Dec 15, 2014 | 04:51 AM
Hmm..
Old Dec 15, 2014 | 08:40 AM
Mustang5L5's Avatar
Lots of these aftermarket bulbs are cheap, chinese crap....even the "good" aftermarket bulbs. Mine burn out all the time. Would have stuck with the OEM bulbs if they weren't so boring looking.
I get maybe 2 years out of each set i've bought. Usually the same thing happens. One bulb goes out, but if i turn off m lights and turn them back on, it sometimes comes back on.
Old Mar 23, 2015 | 11:01 PM
6SJ's Avatar
6SJ
Yeah true sometimes if you mess with The lights it will randomly come on, and after market headlights are cheap!? Really? Would they burn off quick or something becuae I really don't want to stay with OEM I want maybe black spyder headlights, or if any suggestions post them up.
Old Mar 24, 2015 | 11:04 AM
Mustang5L5's Avatar
The bulbs is what i refered to. D2R or D2S depending on reflector or projector housings.
All these $10 bulbs you get on Ebay or from various vendors are cheap Chinese crap. As i write this now, ony of my aftermarket 5K bulbs is starting to go Yellow...a good sign that it will burn out soon. I usually get 1-2 years out of each set before 1 craps out on me. But for $10-15 plus shipping, i'll just order another set and go on for another year or so.
With OEM bulbs, you are stuck with 4.3K, however they are made by reputable manufactuer's like Phillips Osram and last much longer. More expensive ($50-60/pair) but will last you a while. (or at least should).
As with anything, you truely do get what you pay for.
Old Mar 24, 2015 | 06:07 PM
Originally Posted by Mustang5L5
The bulbs is what i refered to. D2R or D2S depending on reflector or projector housings. All these $10 bulbs you get on Ebay or from various vendors are cheap Chinese crap. As i write this now, ony of my aftermarket 5K bulbs is starting to go Yellow...a good sign that it will burn out soon. I usually get 1-2 years out of each set before 1 craps out on me. But for $10-15 plus shipping, i'll just order another set and go on for another year or so. With OEM bulbs, you are stuck with 4.3K, however they are made by reputable manufactuer's like Phillips Osram and last much longer. More expensive ($50-60/pair) but will last you a while. (or at least should). As with anything, you truely do get what you pay for.
Morimoto makes great aftermarket D2 bulbs in various color schemes. Buy what works for your preference.
Old Mar 31, 2015 | 12:20 PM
Mustang5L5's Avatar
Already got a set, but thanks I'll consider them (if i remember) the next time around.
Old Apr 2, 2015 | 04:47 PM
driftsucky's Avatar
If they keep going out, check the cover on the back of your headlight that protects the ballast. Mine kept doing that and, unbeknownst to me, I kept getting road crap in my ballast and THAT'S why my light kept going out. But, look into it.
wonderizm
Sep 24, 2015 03:09 AM
Nick_M
Aug 3, 2015 11:08 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
