white smoke and burning of oil
Old Jan 8, 2015 | 05:49 PM
tizzy56's Avatar
i have a 04 G35 coupe 6 spd. cheeck engine light came on and i have a **** load of white smoke coming out of my exhaust and its smells like burning of oil... what is the cause of this problem?
Old Jan 8, 2015 | 06:17 PM
Urbanengineer's Avatar
Overfilling probably. Check you level on a level surface.
Otherwise maybe you have the ole manual coupe oil burning issue.
Old Jan 8, 2015 | 06:40 PM
tizzy56's Avatar
its not a overfill..oil levels are normal. i replaced cats with straght pipes and regular exhaust system. everything was ok. till i warmed up car one day for about ten minutes.. the i saw alot of smoke started coming out the bottom of car not engine bay and check engine light came on smh
Old Jan 11, 2015 | 01:30 PM
Blue Dream's Avatar
I drove ttrank's car solo
You need to get the code/s read and go from there.
Old Jan 13, 2015 | 10:10 PM
j_mullet's Avatar
I was doing a sparkplug change on the g and managed to break the pvc (pcv??) Valve on the passenger side. I figured I would glue it back together until I could get one. It was chucking heavy blue clouds until I replaced that valve. Hope that might help. Good luck!
Old Jan 14, 2015 | 08:32 PM
dbarnes's Avatar
If it's burning that much oil you should be getting at least a "Random Misfire" code, and probably codes for the Catalytic Converter malfunctioning and various others stating that emissions are not within acceptable values.
If your car ate a valve like mine did, you'd know it, because you're running on 5 cylinders and it will run extremely rough and buck and jerk when you try to accelerate (although once up to 75 or 80 MPH it smooths right out as you cruise). But you will also get the thick white oil burning smoke you are describing.
My $0.02
Old Jan 15, 2015 | 08:19 AM
05CoupeMT's Avatar
G35 Coupe 6MT
the oil burning issue was on the revup models. 05/06/07 6MT
Old Jan 15, 2015 | 10:02 AM
JOKER's Avatar
CLUB MODERATOR
you should be getting little more smoke coming from your exhaust dues to straight pipes vs cats, but it should not be excessive. Read your code. It it refers to oxygen sensors on exhaust then that is your problem.
magnetism80
Feb 1, 2019 10:00 AM
cmesidewayz
Sep 29, 2015 09:28 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
Machine Head
Sep 4, 2015 07:22 PM
Eomfd
Aug 29, 2015 12:42 AM
