VK 56 swap
Old Feb 26, 2015 | 06:16 PM
ajeezy87's Avatar
VK 56 swap
Hello, new user here. I have a 07 g35 coupe. I have been doing quite a bit of research on the swap and am set on doing it now.One of the main things i cant seem to find much info on is how the engine must be mounted or if any fabrication has to be done i.e.(strut towers,mounts) so if anyone could help i would greatly appreciate the info.
Old Feb 26, 2015 | 09:26 PM
ScraggleRock's Avatar
You won't..
Old Feb 26, 2015 | 09:32 PM
ajeezy87's Avatar
Originally Posted by ScraggleRock
You won't..
Won't what?
Old Feb 26, 2015 | 09:35 PM
Originally Posted by ajeezy87
Won't what?
Swap swap swap
Old Feb 26, 2015 | 09:39 PM
ajeezy87's Avatar
i will, just need more info.
Old Feb 26, 2015 | 09:41 PM
I'm not trying to detour you, in fact there's no one who'd like to see it more than I. Its gonna be a long hard road tho.
Old Feb 26, 2015 | 09:43 PM
ajeezy87's Avatar
o, believe me i know from what ive seen. but im a technician with multiple shops and tools at my disposal and i have friends who weld so my biggest expense really would be parts. i just need to have a basic blue print of what i need to do.
Old Feb 26, 2015 | 09:45 PM
brycealbr's Avatar
I wish I knew the answer to you question but don't be deterred figure it out and let us know how awesome it is.
Old Feb 26, 2015 | 09:46 PM
ajeezy87's Avatar
found this http://mckinneymotorsports.com/prod_VK56++350Z+swap but doesnt really go into detail...
Old Feb 26, 2015 | 09:55 PM
bluedevils95's Avatar
If you do this i am interested in seeing if you do this or not. I already have the power i needed but here to see you do this successfully
Old Feb 26, 2015 | 10:05 PM
I looked into this once just for fun and there's a LOT of hurdles to jump. Lots of computer issues due to multiple reasons that I can't recall specifically off hand. I'm assuming you would have to gut everything and probably build a new dash. Plus, does any VK have a 6spd mated to it? I would hope you wouldn't go auto, in which case, which tranny to use that's computer compatible?
Frankly an LSx swap is smarter, but the VK would be extremely unique.
Old Feb 26, 2015 | 10:12 PM
Mr. Brooks's Avatar
Great men never became great by doing things the easy way. Greatness and easy don't go hand in hand. Once you get your swap done and operating flawlessly others will follow.
Old Feb 26, 2015 | 10:17 PM
ajeezy87's Avatar
trans from g35 bolts to the engine with an adapter plate and the wiring harness plugs into the ecm as well i would most likely imagine it will have to be flashed or just have to get a stand alone module seeing as im goin from 6 to 8 cylinnders but like i said my main issue is mounting and seeing how much fabrication needs to be done. so any help even the slightest, links or otherwise would be appreciated.
Old Feb 26, 2015 | 10:24 PM
Haha ooook, problem is its not greater than an LSx. Its just more difficult. With all the aftermarket options for LS motors its easily the better choice.
(Again, not to detour, I'd love to see it, but facts is facts.)
Old Feb 26, 2015 | 10:31 PM
Mr. Brooks's Avatar
I wonder if Top Secret used an LS motor when they dropped a V8 in a G35 coupe and added twin turbos. Yes the LS is easy and yes it works but, the engine design is old and Chevy has used the same design for decades adding power along the way but, what he's doing will have a lot of followers.
