Possible Camshaft sensor gone
Old Apr 6, 2015 | 10:06 AM
Gorhad's Avatar
Did he have the same symptoms
Old Apr 6, 2015 | 10:44 AM
Siciliang35's Avatar
Try resetting the ecu . If that dont work double check Your oil level, and make sure the sensor and connection is snug . Check Your timing.
If light comes back on pull the codes again
Next charge the battery, and have the starter checked out like someone said. If all that is ok then check for a bad ground or short
Keep us posted .gl
Old Apr 6, 2015 | 10:46 AM
JKL1031's Avatar
Yes we went thru the sensor dance and no luck. His car was actually not starting all the time tho. Try swapping the other cam sensor on that side with ur brother. This one is like on the exhaust cam and has a angled connector.
Old Apr 6, 2015 | 08:04 PM
Gorhad's Avatar
Reset the ecu multiple times to no avail. Charged the battery still nothing. Check timing how ? Light comes on and it's the same code. I'll get the starter checked out too and God the ground. Yes I will try the other sensor too but being as it pulled bank one I believe the bank 2 wouldn't trip it but I'll try it.
Old Apr 7, 2015 | 11:13 AM
JKL1031's Avatar
Same back just on the other cam.
Old Apr 7, 2015 | 11:15 AM
JKL1031's Avatar
I bought sensor 23731 6J90B and had this problem less than a day. Do u still have the pack from nissan?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
