New G35 with maintenance questions
Old Jun 23, 2015 | 05:59 PM
mbe32's Avatar
I recently purchased an '06 G35 with 100k km (60 k miles) and am doing some maintenance to get everything up to date.
I'm changing out the rear pads and rotors but I'm having a heck of a time trying to get the caliper bracket mount bolts off. The caliber slider pins came off quite easy but the caliper bracket bolts won't budge even after using some penetrating oil and letting it sit overnight. I'm thinking they could be seized as the rotors are possibly original and have never been taken off. Any tips on how to get the bolts out? I don't want to round the bolts off and end up having to cut them off.
I'm going to change the transmission fluid (auto) and was wondering about the specified oil to use. I have some Valvoline Dex Merc which says it can be used in Nissan/Infiniti where J-Matic is specified but I've read elsewhere that only Nissan/Infiniti ATF should be used. Is is okay to use the Valvoline? Also since there is no filter to change I guess the best approach would be to drain/fill x 3 to try and get most of the fluid out?
I only got one key with the car (intelligent key) and was wondering how to go about getting a new one made. The dealer wants $350 for a replacement key. Can I buy a used intelligent remote on eBay and have it programmed by the dealer? Is the transponder chip in the mechanical key or the actual remote key itself?
Old Jun 23, 2015 | 09:08 PM
Urbanengineer's Avatar
The correct oil for the transmission is cheap, replacing a transmission is not.
Old Jun 23, 2015 | 10:29 PM
coffeysm's Avatar
Pull out the slide pins and hang the caliper with a piece of rope or bungee cord. Take a propane torch and heat the bolts up for a few minutes. Then use a 1/2 bar to take the bolts off.
That's how I got both of mine off since they were on real tight. I used penetrating oil also a lot of it.
You don't want to use heat around the brake hoses if it absorbs enough heat the fluid will explode.
I'd go with the Nissan fluid or Idemitsu Type J. I put Idemitsu in when I did mine and haven't had a problem since. You might find some deals on eBay.
You can get a blank key off eBay; I've done it before without problems. If you separate the key from the fob there is a number in there. You need to find the same number on eBay and then bring it to the dealer. Just make sure it has an Infiniti icon; I've read of some people getting denied by the dealer if it doesn't. Otherwise you'd need to find a locksmith to do it for you.
Old Jun 24, 2015 | 01:40 AM
mbe32's Avatar
Thanks for the info. I was able to break the bolts out by tapping the wrench with a hammer. I'll stick with the Nissan fluid. How many quarts does it take during a drain and refill?
Old Jun 24, 2015 | 02:39 AM
coffeysm's Avatar
I don't remember exactly, but I think it was between 2-3 maybe 4 quarts (depending how high, angle, etc.. you jack it up). I bought one of those juice jugs for a dollar at Rite-Aid. Drained into a pan then filled the jug up to see how many came out.
Do it while it's cold or wait for the fluid to cool off when you replace it. It expands when it's hot.
Old Jun 24, 2015 | 09:33 AM
gary c's Avatar
All very good advice ^ use only Nissan AT fluid in your transmission. Don't forget about the other fluids that need replacing at 60K miles, brake and radiator! I'd also replace the belts and cabin filter too...Gary
Old Jun 24, 2015 | 11:56 AM
Spartan268's Avatar
I'd also add spark plugs to that list. It says it lasts for as long as 100K (miles). But I would not recommend this at all, especially since the car is already almost 10 years old
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Frostbite91
Jul 27, 2015 05:25 AM
laksjd84
Jul 24, 2015 05:12 PM
korfak
Jul 20, 2015 12:10 PM
