HELP!! 04 g35 with suspension package from Infiniti
![Angry](https://g35driver.com/forums/images/icons/icon8.gif)
I brought my car with the suspension package. Seems like every 6 months I am buying new tires due to a horrible camber problem.. Brought it to several shops including the dealership all told me nothing can be done
I am tired of buying tires other than having the package removed which most likely will cost me an arm and a leg anyone know anything I can do
Anyone know if thier is some type of recall??
I posted the 2 front tires brought these in February had them changed today
The back tired I can get one year of driving unlike the front which is about 6mths
The one that was worn the most is the right front
Help
Also seems as if my fuse had blown for my fog, the strip on the side of the head lights and my trunk. I can't locate these fuses
Any other box other than inside driver side and by the batt???
Help
Unless you have lowering springs, you have a problem with the front end. Find a shop that knows what they are doing.
Just looking at the pic, it's "toe" AND camber problems. If it's only one tire, did you ever hit anything? Have you had it since new? I am lowered and I got mine back close to stock specs but not perfect.
Sorry was away didn't check my replies
Yes this was from the factory no mods on the car
I get 6mths from my front tires which are ones in the photo and 1 year from the rear
I tried everything from cheap tires to expensive ones!!
I'm going to read more of these comments and answer what I need to
Thanks for everyone's help
Well the trunk light fuse is there which is what I thought you were talking about, but now from your last statement I think you are talking about your trunk release circuit, is this correct? If yes I will get back to you on that one.
