tien tie rods grind bump stop?
Old Mar 11, 2016 | 07:50 PM
Siciliang35's Avatar
Im changing the inner outter tie rods tomorrow to tien. Do i need to grind down the bump stop like it says on this dyi . Check above number 3
http://my350z.com/forum/brakes-and-suspension/537394-tein-inner-and-outer-tie-rod-replacement.html
Another question is
Both inner and outters are bad and its been eating the inside of the tires. Its mostly the side closer to the rotors. If i don't get to do an alignment this weekend how would i adjust it ? Would putting a level on the rotor help? I got long ride to work Monday. Thanks for any help.
I got alot to change this weekend. Im doing the control arm bushings , rear sway bushing and both front wheel bearings.
Snazzysara
Feb 23, 2016 02:46 PM
FuriousVegan
Feb 18, 2016 11:41 PM
Tbrown930
Feb 13, 2016 12:13 PM
Finnkc
Feb 12, 2016 05:49 PM
