1st and reverse Grinding Noise
Old Apr 11, 2016 | 12:27 PM
NathanielV35's Avatar
When i come from a complete stop going into first i get a grinding noise, no matter how i play with the clutch/acceleration. I was told the clutch is sports clutch (i just got the car a month ago) idk about the flywheel. reverse is usually louder and worse than 1st. It only happens from a complete stop. If im already moving it wont happen. 124k miles. Maybe im a shitty driver (1st manual car) feedback ill post vids
Old Apr 11, 2016 | 02:37 PM
partyman66's Avatar
Your clutch may not be fully disengaging. If the car is stopped and it's grinding going into gear then it's not a drivers skill problem and likely mechanical. Try to get it fixed ASAP before it turns into a blown tranny.
Old Apr 18, 2016 | 01:13 AM
when im at a complete stop and i start letting go of the clutch for first gear to catch i get a little rattling/ gear noise. The guy said it was a sports clutch and the biting point is near the top of the clutch pedal. Maybe he lied and i need a new clutch? throwout bearing? it gets worse on an uphill. i might just take it to a shop. sometimes it does it not all the time but frequently
Old Apr 18, 2016 | 01:14 AM
when im in neutral there is a rattling its just going from a stop to rolling in first.
Old Apr 18, 2016 | 01:23 AM
partyman66's Avatar
Could be a busted finger on the pressure plate.
Old May 1, 2016 | 08:25 PM
G34.5and1/2's Avatar
Sport Clutch...Ha! Funny! .....What he meant was Sport you need a clutch!
NunButaGthang
Jun 24, 2016 01:13 AM
Sean13
Apr 25, 2016 02:53 PM
Black_Out
Apr 12, 2016 09:13 PM
TreyEdwards
Apr 11, 2016 09:25 AM
