04' G35 Coupe - 249K Miles - Engine Ticking
Old May 16, 2016 | 09:51 PM
gmarshiii's Avatar
Hello Everyone
I have a '04 G35 Coupe with 249,300 miles with a very noticeable engine ticking noise. Here are two recordings....
Recording #1
Recording #2
Thanks for any input on what is causing this so I get an idea of what my strategy will be...hoping to prolong the life of this amazing vehicle another a year if not two!!
Old May 17, 2016 | 01:01 PM
telcoman's Avatar
Veteran: Army
Originally Posted by gmarshiii
Hello Everyone
Sounds like possible worn rings or connecting rod bearings
Try doing a compression test.
I see either an engine rebuild or a trade in in your future
Start saving $$$
Telcoman
Old May 17, 2016 | 08:50 PM
Mignav01's Avatar
sounds like a valve clack. Low on oil??? had it on my car then I realized I was about a quart and a half low. If not then it's probably a con rod
Old May 18, 2016 | 04:36 AM
partyman66's Avatar
That's pretty good that you got this many miles out of your G. Can you tell if it's coming from the top or the bottom of the motor?
Did it come on suddenly or has it been gradually getting worse?
Old May 21, 2016 | 11:22 AM
meygoren's Avatar
I have 133,XXX miles on my 04 g35, and I have a similar tick, I was told that it was the lifters in my valve cover. They need to be gapped over time.
Old May 24, 2016 | 11:39 PM
Invalid_User's Avatar
Take it to a mechanic
VQ35Monstar
Engine - Exhaust
Mar 23, 2016 11:44 PM
maximebeauvais
Mar 23, 2016 10:14 PM
FuriousVegan
Engine - Exhaust
Mar 23, 2016 06:28 PM
SS G35
Feb 29, 2016 06:23 PM
