Cracked upper oil pan, JB Weld?
Old May 22, 2016 | 03:32 AM
ZBigKahuna's Avatar
Well, I just cracked my oil pan. Trying to put my motor back together and got all the way down to the oil pan. As I was screwing it on I suppose it was bottoming out on one of the arp main studs I installed, and the stud cracked part of the pan. Crazy thing is that I wasn't even wrenching hard on it at all. Here's a picture of the crack, there's no chunks of the metal missing but the crack is definitely there. Is it possible to fix this with JB Weld or other epoxy or am I best off replacing the pan?
Old May 22, 2016 | 10:46 AM
eazdaskeez's Avatar
Jb weld should suffice
Old May 22, 2016 | 11:10 AM
ZBigKahuna's Avatar
Awesome. Any recomendations for applying it other than clean the surface really well? And should it be on the inside and outside, or just the outside?
Old May 22, 2016 | 07:39 PM
eazdaskeez's Avatar
I would do both to be honest. Just be sure to clean the surfaces very well
Old May 22, 2016 | 07:46 PM
eazdaskeez's Avatar
After a bit of research you have a 50/50 chance with this. Tread lightly
Old May 22, 2016 | 08:12 PM
Frankieg35's Avatar
Just replace it, a used one can't be that expensive
Old May 23, 2016 | 12:23 AM
DeafBringer's Avatar
What frankie said. You have easy access to it, just replace it.
youngdip631
May 12, 2016 09:37 PM
ninjabong
May 4, 2016 05:17 PM
Juan87R
Lighting
Apr 28, 2016 04:40 PM
Sepsis
Apr 26, 2016 11:23 AM
jonathan-mayea
Apr 22, 2016 07:09 PM
