06 g35 headlight question
Old Jul 26, 2016 | 10:16 PM
demokds's Avatar
i have a 06 g35 headlight i wanted to clean the inside because it was too foggy and i tried to clean it with everything i had in my house and it still looks foggy how can i put it crystal clear? here are some pics.
Old Jul 27, 2016 | 12:24 AM
Blue Dream's Avatar
I drove ttrank's car solo
You can't clean the inside of the lens like you do the outside. It has a coating/film on it and cleaning attempts make it look worse than it did. Time for new lenses (almost impossible to find), new lights or dealing with what you have.
Old Jul 27, 2016 | 09:32 PM
zcherub's Avatar
Assuming you haven't already screwed it up by trying to clean the inside, it may be salvageable. If the "foggy" look is due to repeated heat/UV exposure, they can sometimes be sanded back to close to their original clarity.
If sanding doesn't work, or if your cleaning the interior already fubar'd it, you'll have to buy new lights. I recommend OEM as output from most eBay lights are trash by comparison.
Old Jul 28, 2016 | 01:57 AM
Urbanengineer's Avatar
If it's just condensation from a wet day, throw one of those bead packets from a new shoe box in your headlamp to absorb the moisture. If it's wear on the inside, prepare to spend $300 on lenses or accept you have non-perfect lenses.
Old Jul 29, 2016 | 03:24 PM
demokds's Avatar
what about new lense
Old Jul 29, 2016 | 07:35 PM
demokds's Avatar
i got this aftermarket headlight can i just swap the lenses? or it cant be done?
Old Jul 30, 2016 | 02:13 AM
Blue Dream's Avatar
Hard for me to say, I know nothing of the lights you show.
Old Jul 30, 2016 | 04:32 PM
ScraggleRock's Avatar
Holy crap those lights are complete ****. Haha
You should be able to swap lenses tho.
Adversely, you might try (I've done this) removing all the electronics, put some soap and water in there, rinse them out really well and then use some spot free dishwasher stuff (like jet dry or cascade) and distilled water a few times to rinse them out thoroughly. Then to be extra sure that there won't be water spotting inside, blow them out with compressed air until completely dry. You'll need an air compressor (obviously) to do this.
Old Jul 30, 2016 | 10:21 PM
You probably have to dremel off some of the tabs that click into the back housing, but it should fit. Thanks for reading my last post.
HypedAndy
Apr 25, 2016 09:16 AM
JayVQ
Lighting
Feb 15, 2016 01:14 PM
TYJUS
Midwestern
May 7, 2012 05:34 PM
GThang
Dec 4, 2002 02:54 AM
